Explorer problem
fatone
hey! somethings wrong with my explorer. it has to restart every few seconds and i dont know why. i keep on scanning my laptop for a virus but nothing comes up. anyone have an idea as to what the problem could be? :D
have you gone in the command line and typed sfc /scannow
try it in safe mode....
Fully agree with the above suggestion . Reboot system in Safe Mode and see what happens , If issue does not re occur then try to disable the startup programs and services and then restart system in normal mode. Then try to identify the culprit startup application by enabling the startup apps one by one. If Explorer still crashes in safe mode try to run a spyware scan using SpySweeper .
Which explorer? Window or Internet?
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
windows explorer. it still happens in safe mode. i did the sfc / scannow in the command promt and a file came up. is it the file causing the problem?
that's probable, hence the suggestion for running sfc /scannow.
Which file did come up? have you written it down?
    Limneos
    Intel Core2Duo E4500 2.2GHz
    Asus P5LD2-X/1333
    2GB 800Mhz Kingston DDR2
    Nvidia 8500GT
