explorer.exe problem
XxSwiftyxX
Swifter than you!
Power User
Well Vista is starting to get on my nerves with this one, Im trying to do a little spring cleaning in my folders and stuff organizing it and what not then sometimes when I right click something it will freeze then say, Explorer.exe has suddenly stopped responding and then it says to restart it so I do and its on certain programs that it does this.
Is there any way to fix this thank you again.
    Customized
    Intel Q6600
    P5Q Pro
    6 gigs
    XFX GTX260
    on board
    RCA 27", Viewsonic 19"
    1168x664
    456 gigabytes
    600 StealhXstream
    NXZT hush
    Fans
    Razer DeathAdder
    Razer Lycosa
    Don't know
You have a corupt file or driver somewhere.
You can spend several days trouble shooting and "trying" to fix it.
Or you can spend several "hours" reformating and reinstalling your programs.
Its not a matter of if it can be fixed, its the most economical way it can be fixed.
Its mid week. You want to dig and screw around, cuss, yell at the kids, till this time next week?
Format.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA 1 250GB Western Digital SATA 1 200GB Maxtor SATA 2x160GB Western Digitals SATA 1 320GB Seagate External 1 120GB Western Digital External 1 80GB Westen Digital External 1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
If you don't backup regularly, and you have files that you positivily can't lose.
You risk everything.
We are all broke. THe republicans made sure of that. But blank CDs are cheap enough.
Get em, do your backup and fix your problem. If you arent going to take advice, asking for it is useless.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
You don't even really need to backup with Vista if you want a quick re-install. I've installed Vista straight over a Vista installation before, purely because I really couldn't be bothered to wait for my hard drives to format, and it didn't replace the old files - it shoved the whole previous installation into a folder called Windows.old, and then installed the new files on to C Drive. You can then go in to this Windows.old and get all your old files from it, then once you have everything, just delete it to free up all that space.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Everlong judgeing by your post you've never installed Vista.
Formating a drive takes less then 30 seconds. Hes already got Vista installed not XP.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
With the update disk I had, I could only update it through installing XP, so when I got hold of the retail disk, I didn't really have an idea of how long it took to format with Vista, so 30 seconds isn't bad, I'll bear that in mind.
Though the point of the post wasn't the format time, it was more to do with the point of installing it over Vista to keep files...
    ASUS Xonar DX
    100Mbps
