Explorer.exe crashing on ANY right-click
ewmusic39
I have been having this problem for some months now, and I do see that others have had *almost* the same problem, but only occasionally. I can't seem to get anywhere with the solutions on the other threads, either. But any time I right click on anything on my desktop or in the Windows explorer, explorer immediately stops working and has to restart itself. While I have found a few ways to get around it, I really would like to get it fixed completely.
Welocme
Do you have the most up to date explorer 9?
If I'm reading it correctly in the Event Viewer, I'm apparently running version 6.0.6002.18005 Where do I update that, from Microsoft's website?
I have just read your first post, again and aplogize.
Lets see if we can limit the cause to only one.
Do you have any problems in safe mode?
Run an updated and full anti virus scan
Download and make a full scan with malwarebytes
Hello there,
Most of the times the Explorer crashes due a bad or corrupt Context Menu the best way to troubleshoot is to download the ShellExView is an excellent tool to view and manage all installed shell extensions. The rule is to disable non-Microsoft context menu handlers *one-by-one* and verify if the problem is solved. If disabling one does not solve the problem, undo the disabled item and disable the next non-Microsoft handler. Do the same until the problem is solved and finally identify the culprit. Scroll right to see the Company Name column in ShellExView.
Regards,
Captain
