excessive graphics lag
razorfinn
hi again,
I'm having some graphics lag issues, and its never happened before until I installed and subsequently rolled back the new graphics drivers i downloaded. I noticed there was lag when I watched videos online, where I used to have no lag at all. Also, whatever was happening was also taxing my processor pretty bad. When I checked my processes, I found an instance of rundll32.exe that had some command like this:
Code:
C:\Windows\system32\rundll32.exe C:\Windows\system32\NVSVC64.DLL,nvsvcInitialize
and its taking up about 30% to 45% of my processing power. is there a way to slow this down and stop the lag?
Thanks!
I would definitely install the latest driver. Should fix the problem.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
look at your startup items in system configuration
(start , all programs , accesories , run and type msconfig and hit return)
in there youll find a "nvidia compatible display driver" entry if you look ast the command you'll see its NVSVC64.DLL , disable that startup item and reboot , see if it solves the issue , i have never let this startuip item run and have never had any issues ingame or otherwise so its safe to disable :)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
