Ethernet connection problems
bljendro
I'm having trouble getting my laptop to connect to the internet at work. I've connected with no problems previously, but the other day it stopped working. It now just says that it has limited or no connectivity. There's another computer connected to the same router that works just fine, and I have tried using different plugins on the router as well as different cables. It's not my ethernet jack, because I can still use it to connect to my router at home.
The problem began after changing the key used for encryption on the wireless router we use at home. However, this change hasn't affected my ability to connect to the internet anywhere else (school, a friend's, the local coffee shop). I've checked my drivers, and they are all current.
Check the encryption is the same on the Office modem as it may be locked into lets say wep when it should be wpa or it may not be detecting it.
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
