ERROR!!! XVID.dll not found?
hi
when i start a movie i get 1 or 2 little boxes appear stating xvidcoe.dll not found?
the movie plays but still i get the boxes?
any advice info on this issue would be much appreciated
thanks
    acer aspire revo
    intel atom 230
    2gb
    integrated nvidia ion
    lenovo n5901
    lenovo n5901
Hello Billybellfoot,
In order to assist you further, I would request you to help me with few details.
-- Since when are you facing the issue?
-- Which media player are you using to play videos?
-- Were there any recent updates?
Please write back, would be glad to assist further.
Thanks & Regards
Allan D
#iworkfordell
hi thanks for reply
roughly the last week or so
vlc media player
no recent updates
thanks foryour help much appreciated
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
Thank you for replying. Couple of things that can be tried which might help us in fixing the issue.
1. Uninstall and re-install VLC media player. Uninstall the program from Programs and Features - Remove Uninstall Entry. Once uninstalled, re-install VLC Media Player and check the functionality.
2. Try playing the same videos on a different media player like Windows media player and check if you get the same error message or the pop up.
Please write back, would be glad to assist you further.
Thanks & Regards
Allan D
#iworkfordell
hi sorry for late reply have not been at the machine in question.
i have tried both steps suggested above but still recieving xvid core error.dll message?
thanks for helping me with my issue
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
Please refer the article and the try the steps as mentioned which might help us in fixing the issue. It is a third party link which has the fix for the issue.
Please write back for further questions.
Personally I don't recommend getting any dlls from any source other than the program's creator because the source might have maliciously altered the file. Also the problem might not be with that file but with a dll that is referencing that file. In this case I think that the file is associated with either divX or Xvid. If you have either installed I would try updating the application with a fresh download from their respective website. I hate to sound callous but I strongly disagree with Allan's recomendation.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
hi thanks for replys i dont have xvid or divx installed? and have to agree i wasnt keen on the idea of downloading dlls. not callous (difference of opinion..) as i dont have either installed what do you reccomend?
thanks
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
Do you know if you have any codecs installed? Have you tried media player?
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Hi Billybellfoot,
Try performing a System Restore
**Note: By performing a system restore there would not be any data loss but any recent software or program installed would be lost.
Please try the step and check the functionality.
Since you had a codec pack installed it could be looking for it when you play videos as some do require them. If you read the specs it lists both divx and xvid. http://www.mediaplayercodecpack.com/
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
If you play a video that is expecting one then you will probably get that error. Some videos might not even play without the codec. I don't know enough about them enough to know why they are needed but if it where me I would put it back.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
but i didnt use them before and video worked fine i was trying to fix an audio issue that was the reason for installing codec pack. so when i realised the audio problem was a different solution i removed the codec pack.. is it that its not been deleted uninstalled properly?
thanks again for your help
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
Again, just because you didn't use it doesn't mean that the video doesn't use it. More than likely only video editors will actually do anything with the software but you could be playing videos that are trying to use it. My recommendation is to put it back.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
sorry what i meant was videos that played before i installed worked without the error now those same videos produce the error? so its almost as if when i installed or uninstalled it it changed something?
thanks again for your help it is very much appreciated. thanks
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
