Entry point and binary problem, HAVE JAVA!!
Halilbulle
Well everytime i open a new browser a pop up comes up saying;
The proceedure entry point_resetstkoflw could not be located in dynamic link library msvcrt.dll.
Then i press Ok which is the only option, and i get the usual common problem;
Java (TM) Platform SE binary has stopped working.
A problem caused the program to stop working correctly. Windows will close the program and notify me if the solution is avalible. "close programme".
I have java all the updateds ect ect, it wont allow me to open it this same pop up comes up when i press java. I cant play java games, and every new browser does the same thing including pressing google results. Please can someone who has big knoledge with vista help me out, this is my cousins laptop and iv done nothing wrong to make it break.
If you dont want to reply here please reply to me on < Email address removed by Dwarf >
I have java, and its turned on. I cant get into it because this pops up when i press it in control panel.
Open up cmd prompt as administrator by Ctrl+Shift+Enter, then enter regsvr32.exe msvcrt.dll and press enter. If that doesn't work, use the uninstaller here:
Description of the Windows Installer CleanUp Utility
following the instructions and reinstall Java either 32-bit or 64-bit or both if you need it.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Thanks alot, but this problem seems as if its never gonna fix, "The module "msvcrt.dll was loaded but the entry-point Dllregisterserver was not found. Make sure that msvcrt.dll is a valid dll or ocx file and try again.
I clicked your link then download, but it said link was broken and not found.
If anyone can help me they would save my life man im having a rough time explaining to my cousin this isnt my fault.
The site link is up. Just wait for it to load, uninstall Java then reinstall it.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
