e-mails stuck in out box
ukerin
I have been having this problem all day.There are two messages stuck in my outbox messages and they out box are no being displayed. I keep getting a message saying message could not be displayed windows mail encountered an unexpected problem check your computer for low memory or low disk space and try again.Is that the problem how do I check.
Hello Urkerin,
Hard to say if this might be the problem without any system specs. You can make a signiture containing your specs that will be attached to each post so you don't have to keep typing them for each post.
If you are using windows mail you can find info that may help here: http://www.vistax64.com/tutorials/62560-windows-mail-problems.html
I don't use Live Mail so can't help you there, but you can check resource usage by hitting the windows key (opens start menu) and typing in 'reliability and performance monitor' and hitting enter. This will bring up a window that will show you what resources are being used.
Hope this helps.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
Glad its working again.-Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    MX Revolution
