You should upgrade or use an
alternative browser .
Solved DVI to HDMI Adaptor- Improvement or not?
Hi All. I just got a Dell Utrasharp 2408WFP. I'm very pleased with the monitor but have read that, as it's an S-PVA panel, input lag will adversely affect games performance.
Also read, maybe on this forum, that a DVI to HDMI adapter will greatly improve things.
I have such an adapter cable.
Can anyone confirm that it would be better than the DVI to DVI I'm currently using?
I am connecting to a BFG 8800GTS OC 512MB which has 2 DVI ports so should I use it in addition or instead of the DVI to DVI?
The Dell makes Vista 64 look fantastic and it's running like a dream.
Thanks, John
custom build
Q6600 OCd to 3.06GHz
Asus P5Q Pro
Corsair 2x2GB TWIN2X4096-8500C5DF G
XFX GTX 260 Black Edition
1920x1200
2x Samsung Spinpoint 500GB
1x Samsung F1 1TB
Thermaltake Toughpower 650 watt
Coolermaster Cosmos S
Tuniq Tower 120 + 3x120mm + 200m side fan
Roccat Kone
logitech Wave
supposedly 8mbps actually about 4 or 5
love this mouse
Hi John,
Sorry, it will make no difference in quality since it is still a DVI connection just being converted into a HDMI one.
DVI vs. HDMI vs. Component Video -- Which is Better?
Besides that, there is no quality difference between a DVI to DVI or HDMI to HDMI connection on a computer anyway. The only difference would be if the graphics card also supports audio throughput for the HDMI connection so you would not have to run a separate audio cable to the monitor. Most do not.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Hi Shawn. Yep that helps a lot. It saves me messing about around the back of everything anyway.
To be honest I think this monitor is ace as it is. The colours are excellent. I've played Bioshock, Crysis and The Witcher and they all seem as fast as normal. I'm a pretty laid back gamer and don't mind getting killed frequently so I haven't noticed any input lag anyway.
Thanks for your help once again, John:D
custom build
Asus P5Q Pro
1920x1200
1x Samsung F1 1TB
Roccat Kone
logitech Wave
love this mouse
Operating System
Operating System
Perfect timing with that link Shawn
I was just about to start researching what my ideal connection would be for my new screens, looks like the DVI to HDMI that i'm using now is what I want
Operating System
Windows 11 Workstation
Ryzen 9 5950X
Creative
Drive
1500W ThermalTake Toughpower
ThermalTake Level 10 GT
Enermax Liqtech 240
Logitech Performance MX
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
HP CP1515n Color Laser
Microsoft LifeCam Cinema
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
Hey z, why don't you go true HDMI.
As Shawn has said you can run sound through HDMI with the right cards.
I have a true HDMI out GFX card. (one HDMI & one DVI out)
But that would be a lot to invest in, like starting from scratch.
It all depends on what you want to invest in.
When I do build my first, that's the way I'll go.
Later
Ted
* BFK Customs *
Intel C2Q 9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
XFX ATI 1GB 4870 XXX
Realtek HD 7-1
1920x1080P & 1920x1200
Corsair 620HX
CM Cosmos RC-1000
Razer Diamondback 3G
HP Enhansed Multimedia
18.6Mb/s
My First Build ;)
Yeah, I ended up researching all of this not long ago when I upgraded my monitor. The HDMI monitor has a HDMI, component, and audio jack input connections. However, the graphics card only had two DVI connections. Luckily the monitor came with a DVI to HDMI cable. I still had to run a separate audio cable though.
Operating System
Operating System
That's why I was so particular with the GFX card I got.
I could have purchased a better one but few I looked at had true HDMI out.
They all touted that they had HDMI out, to find out it was thru an adapter.
As you say, I still have to run separate audio.
Later
Ted
* BFK Customs *
ASUS P5Q Pro
Realtek HD 7-1
Corsair 620HX
CM Cosmos RC-1000
18.6Mb/s
My First Build ;)
True, but at least the quality is the same though.
Operating System
Operating System
