DVD video not recognised - DVD Roms are?
moan
HI
I've got a bit of strange problem - I have looked in various places on the net and have not found a solution. Hopefully it'll be a simple solution and it's just me being a bit slow (this is my first experiance of Vista so I'm going to blame it on that if it is a simple solution).
Anyway nuff whaffling.
I have just installed Vista premium 64 bit on a home built brand new machine and the DVD drive works with audio CD's, CD-rom & DVD Roms, however when i Pop a DVD-video in the drive the drive spools up but then nothing.
I have tried media centre, media player and "My computer" but the disk isn't even seen.
I have read about decoder problems but as the disk isn't even seen in the drive I don't think it's that.
Oh the Drive is a Samsung SATA drive from my old machine and was working yesterday in the other PC.
Any ideas would be appreciated.
Thanks in advance
L M
    Self Build
    phenom x3
    4gb
Try changing Sata lead to a differnt socket on the motherboard, and reinsert leads to drive.
    INTEL QUAD 6600
    Gigabyte EP35-DS4
    4 gb
    GeForce 8800gt
    24" ACER
    1440 X 900
    500 GB 320GB
    700WATT
    ARCTIC
    Av.MTH, Download 8.27, Upoad 0.91
Thanks for the quick response.
It was getting a bit late last night (small cases look great but are a pain to build) so didn't even think of the old "swap the cable options".:o
Will try as soon as i get home. Stuck at work at the mo. Hopefully will be able to slope off home soon.
Ta
    Self Build
    phenom x3
    4gb
Switched the drive to a different channel and everything works perfectly.
Should have thought of it myself really.
Thanks for the advice.
Moan
    Self Build
    phenom x3
    4gb
