dvd maker photo print?
If you have a photo printer, a cd/dvd media tray for the printer, and the correct template/software. I have a MP610 which I flashed with the australian firmware and got a tray off ebay to do exactly what you're asking for (the mp610 sold in America doesn't support direct disc printing).
Edit: I'm probably an idiot, after second thought I assume you mean print some of the files that are burnt on the cd, I wouldn't see why you couldn't print them?
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Primary 1680 X 1050, Secondary 1920 X 1080
    Logitech MX Revolution
    Satalite :-(
    Running SUSE, Solaris, Kalyware, and BSD through vmware whenever the mood strikes
Thanks for your quick response. Yes, I meant print some of the fles on the burnt dvd. For some reason, I can's seem to do anythng but view the files.
What program are you using to view the files? Is it at all possible to copy the files from the dvd to the computer to print them? I don't use dvd maker so maybe someone can chime in on how it burns discs
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Satalite :-(
