I have the Samsung SH-S223F as my DVD drive, recently it has stopped reading discs, so i can no longer watch DVDs, or get pictures from any of my CDs, its as if there is nothing in the drive. I dont get any error messages except one time it said something about a soundcard driver fault but i didnt read the whole message as it dissapeared, shutting down WMP with it. I do have a soundcard installed (Genius Soundmaker Value 5.1, which i took from my old XP build) but have now reverted to using the onboard sound. Ill remove the soundcard this afternoon to see if that makes a difference.
Cheers
RD
Cheers
RD
- AMD AM2 Athlon 64 X2 6000+
- MSI K9A2 Platinum
- 2GB (2x1GB) Matched Corsair DDR2 Memory 800
- Sapphire Radeon 4870 512MB
- On Board (Upgrade soon)
- 17" :Hansol CRT Monitor
- 1024x768
- 500GB Western Digital Caviar 7200rpm
- PSU
- Corsair TX750W
- Case
- Antec 900
- Cooling
- 3x120mm Case fans, 1x200mm Exhaust Fan, Stock CPU Cooler
- Genius Netscroll+Eye Ruby
- IBM KB-9910
- Up to 16mb usually around 6-8MB
- Other Info
- CPU Temp at almost full load was around 36oC, Graphics Card rarely goes above 58oC
