DVB S2 (TBS8920) Not detected
NelMac
Hi, I just got a DVB S2 tuner and installed it and it appears to be installed correctly.
After considerable tweaking of the software it came with (dvb Dream) I tried it with Media center and it does'nt even appear to be detected as a valid source, getting the message 'no tuner is detected'.
After a bit of looking baout I discovered there is a media center pack which I found and downloaded.
When I go to install it, it says it is incompatible with my system !!!
This is nuts !
I've tried everything and I'm getting no-where fast !
I'm runnning vista home premium 32bit on an asus m2a vm hdmi with an hd4870.
Any ideas anyone ?
Plz !!!!???!!!
    Asus m2a vm hdmi
    AMD 5600+
    Asus m2a vm hdmi
    4 Gb
    Radeon HD4850
    M-audio 2496 (main) and creative live external 24bit (other)
    hanns g hu196 hanns g hc194 and sony bx400 32
    250 Gb seagate, 200 Gb maxtor
    700W HIT
    Generic
    Gigabyte 3d rocket
    microsoft wireless optical
    usb and ps2
    10 Mb
    3xmonitors, I use the hu196 as the main computing display for 'apps' whilst running a sony bx400 32" for media centre using DVB-T and other video whilst the third monitor is located in my bedroom ! USB into all rooms with hubs and wireless keyboards and mice, (with backup ps2 hard-wired keyboard for those moments of battery depletion requiring a change) !
Hello Nelmac and welcome to the forums :party:
Can you post a link to the media centre pack that you downloaded?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
'Can you post a link to the media centre pack that you downloaded?'
Hi Tom, Unfortunately I deleted them !
One was a media pack update 2008
The other was dated 2010.
I have another machine with xp 64bit and the installation went smoothly on that though.
I now have a situation whereby, the other machine is an old machine and doesn't have a very good graphics card installed is not HD compatible !
So, I've now got an HD tuner in a non HD machine !
I downloaded the pack from the microsoft website and it was marked as being compatible with VISTA, however, as I said, when I went to install it, I got the message saying 'incompatible with my system' !!!
Quite strange !
    Asus m2a vm hdmi
    AMD 5600+
    Asus m2a vm hdmi
    4 Gb
    Radeon HD4850
    700W HIT
    Generic
    Gigabyte 3d rocket
    usb and ps2
    10 Mb
Well, I've got it working with DVB DREAM but media center still can't recognise it !
Annoyingly, I removed my M-AUDIO 2496 to make room for the DVB card because the m2a vm hdmi has only 1 pci slot, (being a micro ATX board).
Using an external soundblaster, (sb0490), when DVB DREAM is running flashplayer has lost its AUDIO ! :(
The quest continues !!!!
    Asus m2a vm hdmi
    AMD 5600+
    Asus m2a vm hdmi
    4 Gb
    Radeon HD4850
    700W HIT
    Generic
    Gigabyte 3d rocket
    usb and ps2
    10 Mb
