Dual Screen Problems
Dapke36
Hello All,
I hope someone can help me with this - I used to be pretty good with XP, but now that i've upgraded to Vista, im lost in areas.
Anyways, I had a dual-monitor setup on my machine with XP, but Vista won't allow the same setup.
I am running an nVidia GeForce 7900 GT/GTO with "Automatic Update" for the drivers (i.e. I don't know if they are the newest or not, but they are the ones provided by Microsoft for auto download)
My primary monitor (Acer 20" Widescreen) works fine when plugged in. however, when i plug in my Vison monitor (with a VGA to DVI adapter), and go through the routine of "attaching" the monitor, then setting the resolution, something i've never seen before happens. When I click "ok", the screen goes black for 2 seconds, then re-emerges completey messed up. My primary screen is either in a shade of green or blue, a mix of horizontal "snow", horizontal lines, and a single shade of previously mentioned colors. My Vison (secondary monitor) suddenly jumps up to (at minimum), 800x600 res. The taskbar, icons, menus, and windows all disappear from view (and of course, I can't see anything on my primary except colored snow). I am forced to restart (since I can't see any window to change the resolution). On restart, if I have unplugged my Vison, everything starts normally. If I haven't, it starts with the snow/small resolution combo.
I have tried adjustment in both nVidia's Dual Monitor tool, and the Vista-supplied one. The Acer monitor is recognized in Vistas' Display Settings, but the Vison isn't, when plugged in and "attached".
Also, when I come back to my comp, and my monitor has been automatically shut off, I wiggle my mouse, bringing it to life, and it is filled with that colored snow. Forced restart is the only solution.
Is my graphics card just incapable, or am I missing something?
Thanks in advance for the help. Sorry for the loads of text.
    Personal Make
    AMD Athlon 64 X2 Dual Core 4800+
    Asus A8N-SLI Premium
    2 Gigs DDR-400 (Corsair)
    Creative Soundblaster X-Fi
    Acer 20" W/Vison 19"
    1400x950
    2x Seagate 250 G
    Air-Cooled
I always prefer to get drivers direct from manufacturer. So download them from the nvidia.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0 WD Raptor 36gb 3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
Did so already. Nothing changed for the dual screen problem, unfortunatley.
Do you think I should contact the manufacturer? this almost seems like a flaw on the card, since i've never seen this cropping up before with anyone else.
    Personal Make
    1400x950
    2x Seagate 250 G
    Air-Cooled
Can you take a picture of this flaw?
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    Thermaltake Armor
    Tuniq Tower 120
