dual monitor set up?
manonthemoon
donno if this is the right place but anyways.
i have a radeon 6800 series im not sure which one atm i think 6860
but im trying to set up two monitors and no matter what i do it cannot work
any help? i've tried using the bottom dvi port and it seems not to recognize that the monitor is plugged in. maybe its because both my cords are vgas with dvi converters? any help ive been stuck on this for 2 days now
No youre correct, you should just plug them in, then go into control panel and you'll see both monitors avaliable.
The you just tick the "extend my monitor".
That should do it.
Does the monitor button lights change color when you plug it in?
Do you have the correct drivers for the gpu?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
