Driver_irql_not_less_than_or_equal
getting this over and over. have tried updating all hardware drivers. have run Uniblue Driver scan. no fix. would really appreciate some help here. i am a noob i guess.
Hello,
Could you please follow these directions?
http://www.vistax64.com/crashes-debugging/282419-blue-screen-death-bsod-posting-instructions.html
The dumps are blaming your Atheros network adapter drivers. Try updating them to the latest version.
If you need help with this, please upload your msinfo32 file.
JK said:
Enter msinfo32.exe into the start menu, and press enter. Go to File>Save, and save a copy on your desktop. Right-click on it, and select Send to>New compressed folder. Then attach the file to your next post.
You may also try removing AVG with this tool: http://download.avg.com/filedir/util/avg_arv_sup_____.dir/avgremoverx64.exe
Replace it with MSE: http://www.microsoft.com/security_essentials
...Summary of the Dumps:
Code:
[font=lucida console]
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Debug session time: Fri Oct  1 00:37:11.346 2010 (UTC - 4:00)
System Uptime: 7 days 4:06:52.574
BugCheck D1, {8009d72488, 2, 0, fffffa60066830e1}
*** WARNING: Unable to verify timestamp for athrxusb.sys
*** ERROR: Module load completed but symbols could not be loaded for athrxusb.sys
Probably caused by : athrxusb.sys ( athrxusb+760e1 )
BUGCHECK_STR:  0xD1
PROCESS_NAME:  wmpnetwk.exe
Debug session time: Wed Sep 22 00:15:09.358 2010 (UTC - 4:00)
System Uptime: 0 days 4:43:14.240
BugCheck D1, {c511, 2, 0, fffffa600667b0e1}
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
[/font]
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Looks like I was posting at the same time as Jonathan_King.
Please follow his advice first.
Looks like athrxusb.sys - a component of your wireless USB device.
The drivers on your system date from 2008 ( athrxusb.sys Tue Jul 29 08:47:13 2008 (488F1151) )
I do not recommend using USB wireless devices - much preferring a wireless card that inserts in your motherboard. They are much more powerful and reliable. Also, the wireless USB devices that don't have Win7 drivers are prone to giving BSOD's - so if you can't locate Win7 drivers for this device you're liable to be stuck with the situation as is.
Please remove or update these older drivers that were loaded at the time of the crash. Don't use Windows Update or the Update drivers function of Device Manager.
Please use the following instructions to locate the most currently available drivers to replace the one's that you uninstall OR remove:
How To Find Drivers:
- I have listed links to most of the drivers in the code box below. Please use the links there to see what info I've found about those drivers.
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference
- - Driver manufacturer links are on this page: http://www.carrona.org/drvrdown.html
Here's the older drivers (You can look them up here: Driver Reference ).
Please pay particular attention to any dated 2008 or earlier:
Code:
[FONT=lucida console]
usbcir.sys   Sat Jan 19 01:34:01 2008 (479199D9) - ENE USB Consumer IR Driver for eHome - http://www.carrona.org/dvrref.html#usbcir.sys
AtiPcie.sys  Mon Nov 06 11:59:54 2006 (454F6A0A) - ATI PCIE Driver for ATI PCIE chipset - http://www.carrona.org/dvrref.html#AtiPcie.sys
AVer88xHD64.sys Sun Apr 08 23:47:40 2007 (4619B75C) - AVerMedia 23888 AvStream Video Capture - http://www.carrona.org/dvrref.html#AVer88xHD64.sys
CAXHWBS2.sys Wed Nov 08 19:16:54 2006 (45527376) - Conexant Modem - http://www.carrona.org/dvrref.html#CAXHWBS2.sys
CAX_DPV.sys  Wed Nov 08 19:19:08 2006 (455273FC) - Conexant Modem - http://www.carrona.org/dvrref.html#CAX_DPV.sys
CAX_CNXT.sys Wed Nov 08 19:15:48 2006 (45527334) - Conexant Modem - http://www.carrona.org/dvrref.html#CAX_CNXT.sys
RTS5121.sys  Wed Jun 04 02:06:52 2008 (484630FC) - Realtek USB Mass Storage (Card Reader) Driver - http://www.carrona.org/dvrref.html#RTS5121.sys
RTKVHD64.sys Tue Aug 19 06:00:43 2008 (48AA99CB) - Realtek High Definition Audio Function Driver - http://www.carrona.org/dvrref.html#RTKVHD64.sys
athrxusb.sys Tue Jul 29 08:47:13 2008 (488F1151) - Atheros Wireless LAN USB device driver - http://www.carrona.org/dvrref.html#athrxusb.sys
mdmxsdk.sys  Mon Jun 19 17:27:26 2006 (449716BE) - Conexant Modem Diagnostic Interface x86 Driver - http://www.carrona.org/dvrref.html#mdmxsdk.sys
xaudio64.sys Fri Aug 04 20:42:47 2006 (44D3E987) - Conexant Modem Audio - http://www.carrona.org/dvrref.html#xaudio64.sys
LVUSBS64.sys Fri May 11 20:01:20 2007 (464503D0) - Logitech Camera driver - http://www.carrona.org/dvrref.html#LVUSBS64.sys
lvuvc64.sys  Fri May 11 19:59:12 2007 (46450350) - Logitech USB Video Class Driver (WebCam) - http://www.carrona.org/dvrref.html#lvuvc64.sys
[/FONT]
BSOD BUGCHECK SUMMARY
Code:
BUGCHECK_STR:  0xD1
BUGCHECK_STR:  0xD1
  [/FONT]
Thank you both for the help. AVG is gone and replaced. I am considering just getting a wireless card instead of the crappy USB adapter. Here the rest of my info just to be sure I am not missing something. Thanks again.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Thanks Jonathan. I've installed the Belkin Drivers and have had NO BSOD in the last three days. I am still going to upgrade to an on board wireless card which should arrive tomorrow. Thanks for all the assistance.
Thanks for the report, good luck!
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
