Driver_irql_not_less_or_equal
Throwed
Lately my PC has been crashing a lot and getting the DRIVER_IRQL_NOT_LESS_OR_EQUAL BSOD, which usually shows that ntoskrnl.sys and tcpip.sys have something to do with it.
It would be greatly appreciated if you guys could help me with this problem.
Running Vista Home Premium 64bit OEM
Lot's of errors. Try updating your wired and wireless drivers.
The reports don't contain much info (I'll discuss that later).
If using a Wireless USB device - remove it and uninstall it's software in order to test. With the amount of BSOD's you're getting you should know if that's the problem or not in very short order!
More to follow after work (I'm running the memory dumps while I'm at work).
I'm uncertain if the reports were stopped too early, or if there's an issue with your OS that prevents it from displaying the information. Please regenerate the jcgriff2 reports again and be sure to allow it to run to completion.
20 memory dumps over the last 2 weeks
8 different BSOD error codes
4 different causes blamed
This is most likely a hardware error. They (hardware errors) are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (such as your ATI PCIe chipset driver that dates from 2006 or your Realtek USB card reader - the driver dates from 2008)
- low-level driver problems (such as as your Comodo Firewall)
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
Please uninstall the Comodo firewall and enable the Windows firewall for testing purposes. Once the testing is done and the system is stable, feel free to reinstall Comodo if you'd like it.
You have a number of older drivers that need to be updated. If no update is available, then they should be removed from your system.
Links to the Driver Reference Table (DRT) are included to help you figure out where to update them from:
AtiPcie.sys Mon Nov 06 11:59:54 2006 (454F6A0A)
ATI PCIe chipset drivers
Driver Reference Table - AtiPcie.sys
yk60x64.sys Wed Jul 16 04:07:59 2008 (487DAC5F)
Marvell Yukon wired network driver
Driver Reference Table - yk60x64.sys
RTSTOR64.SYS Thu Jun 05 07:21:42 2008 (4847CC46)
Netgear USB card reader
Driver Reference Table - RTSTOR64.SYS
The following info is just FYI, I've already addressed the issues that I saw in the above paragraphs
- Further info on BSOD error messages available at: http://www.carrona.org/bsodindx.html
- Info on how to troubleshoot BSOD's (DRAFT): http://www.carrona.org/userbsod.html
- How I do it: http://www.carrona.org/howidoit.html
3RD PARTY DRIVERS PRESENT IN THE DUMP FILES
Code:
[font=lucida console]
atikmpag.sys    Tue Feb 14 21:13:12 2012 (4F3B14B8)
epfwwfp.sys     Tue Jun 28 03:30:08 2011 (4E098300)
[Color=Red]AtiPcie.sys     Mon Nov 06 11:59:54 2006 (454F6A0A)[/Color]
[Color=Red]yk60x64.sys     Wed Jul 16 04:07:59 2008 (487DAC5F)[/Color]
GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
agrsm64.sys     Thu Aug 13 11:20:43 2009 (4A842F4B)
atikmdag.sys    Tue Feb 14 21:51:52 2012 (4F3B1DC8)
AtihdLH6.sys    Tue Dec 06 04:14:01 2011 (4EDDDCD9)
RTKVHD64.sys    Tue Dec 13 05:24:54 2011 (4EE727F6)
cmdguard.sys    Mon Jul 06 09:23:16 2009 (4A51FAC4)
ehdrv.sys       Tue Jun 28 03:34:38 2011 (4E09840E)
cmdhlp.sys      Wed Jul 01 07:51:55 2009 (4A4B4DDB)
EpfwLWF.sys     Mon Jul 11 12:19:38 2011 (4E1B229A)
[Color=Red]RTSTOR64.SYS    Thu Jun 05 07:21:42 2008 (4847CC46)[/Color]
eamonm.sys      Tue Aug 02 05:33:29 2011 (4E37C469)
epfw.sys        Tue Jun 28 03:30:10 2011 (4E098302)
[/font]
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=epfwwfp.sys
http://www.carrona.org/drivers/driver.php?id=AtiPcie.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=agrsm64.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=AtihdLH6.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=cmdguard.sys
http://www.carrona.org/drivers/driver.php?id=ehdrv.sys
http://www.carrona.org/drivers/driver.php?id=cmdhlp.sys
http://www.carrona.org/drivers/driver.php?id=EpfwLWF.sys
http://www.carrona.org/drivers/driver.php?id=RTSTOR64.SYS
http://www.carrona.org/drivers/driver.php?id=eamonm.sys
http://www.carrona.org/drivers/driver.php?id=epfw.sys
BSOD BUGCHECK SUMMARY
Code:
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-06.dmp]
Built by: 6002.18607.amd64fre.vistasp2_gdr.120402-0336
Debug session time: Wed May 30 14:03:53.502 2012 (UTC - 4:00)
System Uptime: 0 days 0:03:44.286
Probably caused by : ntkrnlmp.exe ( nt!ExpInterlockedPopEntrySListFault8+0 )
DEFAULT_BUCKET_ID:  COMMON_SYSTEM_FAULT
BUGCHECK_STR:  0x50
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID:  X64_0x50_nt!ExpInterlockedPopEntrySListFault8+0
Bugcheck code 00000050
Arguments fffff800`00000020 00000000`00000000 fffff800`042ace57 00000000`00000000
BiosVersion = 7B3P091G
BiosReleaseDate = 08/06/2008
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-05.dmp]
Debug session time: Wed May 30 13:58:44.612 2012 (UTC - 4:00)
System Uptime: 0 days 0:03:27.362
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceExit+209 )
BUGCHECK_STR:  0x1
FAILURE_BUCKET_ID:  X64_0x1_SysCallNum_30_nt!KiSystemServiceExit+209
Bugcheck code 00000001
Arguments 00000000`771171aa 00000000`00000000 00000000`0000ffff fffffa60`067c3ca0
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-04.dmp]
Debug session time: Wed May 30 13:54:35.999 2012 (UTC - 4:00)
System Uptime: 0 days 0:08:51.789
BugCheck D1, {51eb8537, 2, 1, fffffa6000e7e4ba}
Probably caused by : hardware ( tcpip!TcpRestructureHashTable+3a )
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID:  X64_IP_MISALIGNED
Bugcheck code 000000D1
Arguments 00000000`51eb8537 00000000`00000002 00000000`00000001 fffffa60`00e7e4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-03.dmp]
Debug session time: Wed May 30 01:45:00.109 2012 (UTC - 4:00)
System Uptime: 0 days 0:13:07.299
BugCheck D1, {51eb8527, 2, 1, fffffa6000e744ba}
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xD1
PROCESS_NAME:  League of Legen
Arguments 00000000`51eb8527 00000000`00000002 00000000`00000001 fffffa60`00e744ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-02.dmp]
Debug session time: Wed May 30 01:30:12.479 2012 (UTC - 4:00)
System Uptime: 0 days 0:00:42.603
BugCheck D1, {51eb851f, 2, 1, fffffa6000e7f4ba}
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e7f4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-01.dmp]
Debug session time: Wed May 30 01:28:58.899 2012 (UTC - 4:00)
System Uptime: 0 days 1:06:40.250
BugCheck D1, {51eb851f, 2, 1, fffffa6000e7c4ba}
*** WARNING: Unable to verify timestamp for eamonm.sys
*** ERROR: Module load completed but symbols could not be loaded for eamonm.sys
Probably caused by : hardware ( eamonm+918a )
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e7c4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052912-04.dmp]
Debug session time: Tue May 29 20:06:36.382 2012 (UTC - 4:00)
System Uptime: 0 days 2:25:58.913
Probably caused by : dxgkrnl.sys ( dxgkrnl!VIDMM_PROCESS_HEAP::Free+93 )
BUGCHECK_STR:  0x1a_41284
PROCESS_NAME:  firefox.exe
FAILURE_BUCKET_ID:  X64_0x1a_41284_dxgkrnl!VIDMM_PROCESS_HEAP::Free+93
Bugcheck code 0000001A
Arguments 00000000`00041284 00000000`1532f001 00000000`000090d6 fffff700`01080000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052912-03.dmp]
Debug session time: Tue May 29 17:39:59.314 2012 (UTC - 4:00)
System Uptime: 0 days 0:50:59.262
Probably caused by : ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b8 )
BUGCHECK_STR:  0x7f_8
PROCESS_NAME:  CCC.exe
FAILURE_BUCKET_ID:  X64_TRAP_FRAME_RECURSION
Bugcheck code 0000007F
Arguments 00000000`00000008 00000000`80050031 00000000`000006f8 fffff800`042f1ca4
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052912-02.dmp]
Debug session time: Tue May 29 16:48:25.232 2012 (UTC - 4:00)
System Uptime: 0 days 2:15:07.311
BugCheck D1, {51eb851f, 2, 1, fffffa6000e754ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e754ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052912-01.dmp]
Debug session time: Tue May 29 14:31:52.736 2012 (UTC - 4:00)
System Uptime: 0 days 0:16:12.559
Probably caused by : dxgkrnl.sys ( dxgkrnl!HMGRTABLE::AllocHandle+a2 )
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID:  X64_0x50_dxgkrnl!HMGRTABLE::AllocHandle+a2
Arguments fffffa84`042a0cfc 00000000`00000000 fffffa60`04f1c212 00000000`00000005
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052812-03.dmp]
Debug session time: Mon May 28 14:29:34.286 2012 (UTC - 4:00)
System Uptime: 0 days 0:08:24.461
Probably caused by : dxgkrnl.sys ( dxgkrnl!VIDMM_GLOBAL::ReferenceAllocationForPreparation+22 )
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID:  X64_0x7E_dxgkrnl!VIDMM_GLOBAL::ReferenceAllocationForPreparation+22
Bugcheck code 1000007E
Arguments ffffffff`c0000005 fffffa60`0518111a fffffa60`05372838 fffffa60`05372210
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052812-02.dmp]
Debug session time: Mon May 28 14:20:42.437 2012 (UTC - 4:00)
System Uptime: 0 days 0:15:08.630
BugCheck D1, {51eb851f, 2, 1, fffffa6000e7a4ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e7a4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052812-01.dmp]
Debug session time: Mon May 28 14:05:02.910 2012 (UTC - 4:00)
System Uptime: 0 days 0:24:41.740
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2d67c )
BUGCHECK_STR:  0x1a_41287
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID:  X64_0x1a_41287_nt!_??_::FNODOBFM::_string_+2d67c
Arguments 00000000`00041287 00000000`00000000 00000000`00000000 00000000`00000000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052612-03.dmp]
Debug session time: Sat May 26 14:03:40.592 2012 (UTC - 4:00)
System Uptime: 0 days 0:10:36.773
Probably caused by : ntkrnlmp.exe ( nt!CmpCacheLookup+12a )
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID:  X64_0x3B_nt!CmpCacheLookup+12a
Bugcheck code 0000003B
Arguments 00000000`c0000005 fffff800`044c834a fffffa60`02557970 00000000`00000000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052612-02.dmp]
Debug session time: Sat May 26 13:52:31.589 2012 (UTC - 4:00)
System Uptime: 0 days 0:22:43.803
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2cfdd )
BUGCHECK_STR:  0xBE
FAILURE_BUCKET_ID:  X64_0xBE_nt!_??_::FNODOBFM::_string_+2cfdd
Bugcheck code 000000BE
Arguments fffffa60`000c0000 00000000`cff88121 fffffa60`053625c0 00000000`0000000b
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052612-01.dmp]
Debug session time: Sat May 26 13:29:01.460 2012 (UTC - 4:00)
System Uptime: 0 days 0:00:25.584
Probably caused by : ntkrnlmp.exe ( nt!KiTimerExpiration+10d )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_nt!KiTimerExpiration+10d
Bugcheck code 0000000A
Arguments 00000000`3ed719e5 00000000`00000002 00000000`00000000 fffff800`0426ad4d
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052512-02.dmp]
Debug session time: Fri May 25 15:30:48.594 2012 (UTC - 4:00)
System Uptime: 0 days 0:16:31.407
BugCheck D1, {51eb8537, 2, 1, fffffa6000e774ba}
BUGCHECK_STR:  0xD1
PROCESS_NAME:  dwm.exe
Arguments 00000000`51eb8537 00000000`00000002 00000000`00000001 fffffa60`00e774ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052512-01.dmp]
Debug session time: Fri May 25 15:13:48.418 2012 (UTC - 4:00)
System Uptime: 0 days 0:08:35.574
Probably caused by : win32k.sys ( win32k!xxxDCEWindowHitTest+68 )
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID:  X64_0x3B_win32k!xxxDCEWindowHitTest+68
Arguments 00000000`c0000005 fffff960`001da65c fffffa60`08ef7c60 00000000`00000000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052412-03.dmp]
Debug session time: Thu May 24 18:05:40.490 2012 (UTC - 4:00)
System Uptime: 0 days 0:02:09.615
BugCheck D1, {51eb8527, 2, 1, fffffa6000e794ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb8527 00000000`00000002 00000000`00000001 fffffa60`00e794ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini052412-02.dmp]
Debug session time: Thu May 24 18:02:57.467 2012 (UTC - 4:00)
System Uptime: 0 days 0:06:21.634
BugCheck D1, {51eb8547, 2, 1, fffffa6000e764ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb8547 00000000`00000002 00000000`00000001 fffffa60`00e764ba
  [/font]
Thank you for your response. As of right now i am currently updating the drivers you mentioned and i would like to point out that i uninstalled the COMODO anti-virus a long time ago but parts of it could still exist in the registry. I'll come back later with the results if the updates helped with the BSOD, thanks again.
I also ran the jcgriff2 again and posted it on the OP.
Zip up and upload the memory dumps (they're located in C:\Windows\Minidump).
We'll see what they say.
This is often a waiting game - we fix everything that we can see, then we wait for another crash to reveal more details - then we fix everything that we can see, then we wait for another crash to reveal more details - etc - etc - etc
Eventually the crashes stop and we can say that the problem is fixed - but only after we're sure they've stopped.
Looks like hardware - even most of the memory dumps say that.
Even though you have a couple of older drivers, I'd suggest running the free hardware diagnostics from here:
Code:
atikmpag.sys    Thu Apr 05 21:10:44 2012 (4F7E4294)
yk60x64.sys     Thu Sep 08 03:20:41 2011 (4E686CC9)
AtihdLH6.sys    Thu Feb 23 07:30:07 2012 (4F46314F)
atikmdag.sys    Thu Apr 05 21:48:25 2012 (4F7E4B69)
[/font]
Code:
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060312-04.dmp]
Debug session time: Sun Jun  3 16:26:22.471 2012 (UTC - 4:00)
System Uptime: 0 days 0:03:29.224
BugCheck D1, {51eb851f, 2, 1, fffffa6000e814ba}
BUGCHECK_STR:  0xD1
PROCESS_NAME:  MOM.exe
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e814ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060312-03.dmp]
Debug session time: Sun Jun  3 16:22:13.486 2012 (UTC - 4:00)
System Uptime: 0 days 0:03:41.251
BUGCHECK_STR:  0xD1
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060312-02.dmp]
Debug session time: Sun Jun  3 16:17:39.016 2012 (UTC - 4:00)
System Uptime: 0 days 0:06:51.805
BugCheck D1, {1, 2, 1, fffffa6000966adb}
Probably caused by : hardware ( ataport!IdeMapError+213 )
BUGCHECK_STR:  0xD1
PROCESS_NAME:  wow_helper.exe
FAILURE_BUCKET_ID:  X64_IP_MISALIGNED_ataport.SYS
Arguments 00000000`00000001 00000000`00000002 00000000`00000001 fffffa60`00966adb
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060312-01.dmp]
Debug session time: Sun Jun  3 16:10:01.212 2012 (UTC - 4:00)
System Uptime: 0 days 0:00:24.961
BugCheck D1, {51eb851f, 2, 1, fffffa6000e7d4ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e7d4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060212-05.dmp]
Debug session time: Sat Jun  2 22:45:58.059 2012 (UTC - 4:00)
System Uptime: 0 days 0:04:35.846
BugCheck F4, {3, fffffa8006d97040, fffffa8006d97278, fffff8000453cc90}
Probably caused by : csrss.exe
PROCESS_NAME:  csrss.exe
BUGCHECK_STR:  0xF4_7645660
FAILURE_BUCKET_ID:  X64_0xF4_7645660_IMAGE_csrss.exe
Bugcheck code 000000F4
Arguments 00000000`00000003 fffffa80`06d97040 fffffa80`06d97278 fffff800`0453cc90
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060212-04.dmp]
Debug session time: Sat Jun  2 22:40:34.402 2012 (UTC - 4:00)
System Uptime: 0 days 0:08:27.574
BUGCHECK_STR:  0x3B
Arguments 00000000`c0000005 fffff800`0448b34a fffffa60`0851a970 00000000`00000000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060212-03.dmp]
Debug session time: Sat Jun  2 14:47:08.844 2012 (UTC - 4:00)
System Uptime: 0 days 0:05:14.008
BugCheck D1, {51eb851f, 2, 1, fffffa6000e764ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e764ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060212-02.dmp]
Debug session time: Sat Jun  2 14:40:51.888 2012 (UTC - 4:00)
System Uptime: 0 days 0:06:06.677
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+3106 )
BUGCHECK_STR:  0x19_22
FAILURE_BUCKET_ID:  X64_0x19_22_nt!_??_::FNODOBFM::_string_+3106
Bugcheck code 00000019
Arguments 00000000`00000022 fffff880`00000000 00000000`00000001 00000000`00000000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060212-01.dmp]
Debug session time: Sat Jun  2 14:33:59.814 2012 (UTC - 4:00)
System Uptime: 0 days 0:04:02.601
BugCheck D1, {51eb8527, 2, 1, fffffa6000e7d4ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb8527 00000000`00000002 00000000`00000001 fffffa60`00e7d4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060112-02.dmp]
Debug session time: Fri Jun  1 19:55:49.783 2012 (UTC - 4:00)
System Uptime: 0 days 0:10:29.963
BugCheck D1, {fffffa80248dc0a8, 2, 0, fffffa80078af596}
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+20b )
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID:  X64_0xD1_nt!KiPageFault+20b
Arguments fffffa80`248dc0a8 00000000`00000002 00000000`00000000 fffffa80`078af596
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini060112-01.dmp]
Debug session time: Fri Jun  1 19:44:50.559 2012 (UTC - 4:00)
System Uptime: 0 days 1:05:49.538
Probably caused by : memory_corruption ( nt!MiBadRefCount+4e )
BUGCHECK_STR:  0x4E_9a
FAILURE_BUCKET_ID:  X64_0x4E_9a_nt!MiBadRefCount+4e
Bugcheck code 0000004E
Arguments 00000000`0000009a 00000000`0001d120 00000000`00000002 00000000`00000000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053112-03.dmp]
Debug session time: Thu May 31 16:27:46.790 2012 (UTC - 4:00)
System Uptime: 0 days 1:31:36.876
BugCheck D1, {51eb8527, 2, 1, fffffa6000e7b4ba}
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb8527 00000000`00000002 00000000`00000001 fffffa60`00e7b4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053112-02.dmp]
Debug session time: Thu May 31 14:55:40.618 2012 (UTC - 4:00)
System Uptime: 0 days 0:03:23.775
Probably caused by : hardware ( nt!CmpCallCallBacks+5fb )
BUGCHECK_STR:  0x3B
PROCESS_NAME:  ekrn.exe
Arguments 00000000`c0000005 fffff800`045e566b fffffa60`07366ca0 00000000`00000000
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053112-01.dmp]
Debug session time: Thu May 31 14:51:43.695 2012 (UTC - 4:00)
System Uptime: 0 days 0:02:51.818
BugCheck D1, {51eb851f, 2, 1, fffffa6000e7b4ba}
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_ONE_BIT
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e7b4ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-13.dmp]
Debug session time: Wed May 30 22:13:18.558 2012 (UTC - 4:00)
System Uptime: 0 days 3:42:50.466
BugCheck D1, {51eb851f, 2, 1, fffffa6000e774ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e774ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-12.dmp]
Debug session time: Wed May 30 18:30:00.497 2012 (UTC - 4:00)
System Uptime: 0 days 0:07:32.290
BUGCHECK_STR:  0xD1
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-11.dmp]
Debug session time: Wed May 30 18:21:56.904 2012 (UTC - 4:00)
System Uptime: 0 days 0:00:31.654
BugCheck D1, {51eb851f, 2, 1, fffffa6000e784ba}
BUGCHECK_STR:  0xD1
Arguments 00000000`51eb851f 00000000`00000002 00000000`00000001 fffffa60`00e784ba
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-10.dmp]
Debug session time: Wed May 30 18:20:55.665 2012 (UTC - 4:00)
System Uptime: 0 days 0:47:57.973
BUGCHECK_STR:  0xD1
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-09.dmp]
Debug session time: Wed May 30 17:32:28.383 2012 (UTC - 4:00)
System Uptime: 0 days 0:11:31.568
BUGCHECK_STR:  0xD1
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-08.dmp]
Debug session time: Wed May 30 17:20:26.381 2012 (UTC - 4:00)
System Uptime: 0 days 1:13:29.777
BugCheck FC, {fffffa600ab784b0, 800000001240b963, fffffa600ab78290, 2}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2d0e4 )
BUGCHECK_STR:  0xFC
PROCESS_NAME:  BsSndRpt.exe
FAILURE_BUCKET_ID:  X64_0xFC_nt!_??_::FNODOBFM::_string_+2d0e4
Bugcheck code 000000FC
Arguments fffffa60`0ab784b0 80000000`1240b963 fffffa60`0ab78290 00000000`00000002
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini053012-07.dmp]
Debug session time: Wed May 30 16:06:27.754 2012 (UTC - 4:00)
System Uptime: 0 days 0:07:44.926
BUGCHECK_STR:  0xD1
  [/font]
