This is my first time posting here and I hope I am doing this right.
I was watching a movie on my PC and paused it. When I came back and tried to wake the compuetr the black screen remained. I then turned off the PC and turned it back on and go the blue screen with the following error:
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've been seen this Stop error screen, restart
your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or
software. Disable BIOS memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart your
computer, press F8 to select Advanced Startup options, and then select
Safe Mode.
STOP 0x0000001E (0xFFFFFFFFC000001D, 0xFFFFF8000248E304, 0x000000000000000C, 0XFFFFFA80069E4A00)
iastor.sys - address FFFFFA6000A59CD7 base at FFFFFA6000A08000, Datestamp 48cad508
I am using Vista x64 OEM and have had this computer for about 1 year now. It is a Gateway. I'm unable to retsart in safemode or anything else as it comes back to the blue screen. Does anyone know what I can do to fix this problem?
Safe Mode.
