Driver Problem
Dwardu
So this morning I checked the computer management and found this warning on the compact flash icon
So I tried the update driver software and I got this
How can I fix it?
  • Screen Resolution
    1152 by 864
uninstall the driver (expand the +, right click the item, select uninstall, then click Action > Scan for hardware changes). if that doesn't work, use the disc that came with your motherboard to reinstall the cf drivers. if you have a branded computer, go to the manufacturer's website and look for the most recent drivers.
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
Thank you so much bro! I did the uninstall and scan for hardware changes.
  • Screen Resolution
    1152 by 864
