driver problem: Compocessor & SM Bus Controller
CityStars
Hi every one,
i have installed Windows Vista Ultimate 64-bit
and i have installed all the drivers using the CD's coming with the motherboard and the graphics display adapter.
but still having these two drivers that i can't find them
- Compocessor
- SM Bus Controller
please, can you help me get the drivers for these two elements
PC details:
Processor: AMD Phenom X4 9950 Black Edition
Motherboard: XFX GeForce 8300 ( 1066MHZ)
Display Adapter: XFX GeForce 9500GT 512MB DDR3
RAM: Kingston DDR2 1066MHZ 2GB ( 2 pieces 2GB each)
HDD: SATA Western Digital 1T.B
thanks in advance.
    AMD Phenom X4 9950
    XFX GeForce 8300 DDR2 1066MHZ
    KingSton 4BG 1066MHZ DDR2
    XFX NVIDIA GeForce 9500GT 512MB DDR3
    Realtek HD Audio
    LG 19" WideScreen
    1152 X 864
    WD SATA 1TB
    Asus Vento
    Genius Netscroll+ Superior
    Sky Tech Mini
    512Mbit/sec
Hi CityStars and welcome to Vista Forums :party:
What is the model number of your motherboard (refer to the manual)? What you have quoted appears to be a graphics card GeForce whereas a motherboard would be nForce.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Dear Dwarf, thanks for welcoming me here, it is much appreciated. :o
about the motherboard model, i will try to give you as much information as i can.
i think the model number is: XFX GeForce® 8300 motherboard
here is the some pictures of my motherboard:
you can see more here:
XFX GeForce 8300a mATX Motherboard XFX GeForce 8300 mATX Motherboard [33X-N8300A] - $148.00 : PC Case Gear, Quality case accessories and components
МатеринÑкие платы GeForce 8300 и nForce 750a от XFX | Компьютеры и техника
i hope i provided the information you need.
Thanks again. :)
    AMD Phenom X4 9950
    Realtek HD Audio
    LG 19" WideScreen
    1152 X 864
    WD SATA 1TB
    Asus Vento
    Sky Tech Mini
    512Mbit/sec
Interesting Mainboard kinda raises more questions about naming usage lol, but the SM Bus Controller should be located on the mainboard driver disk that would have come with the board and as for Compocessor i believe its something to do with language type of thing which makes me feel it proberly should be either on the Windows disc or from external third party like one of the following:
Abstract
Association based Natural Language Processing with Neural Networks KIMURA Kazuhiro SUZUOKA Takashi AMANO Sin Information Systems Laboratory Research and Development Center TOSHIBA Corp Komukai siba Saiwai Kawasaki Japan kim isl rdc toshiba derstanding the practical treatment context dependency within the language can also This paper describes natural language pro improved enhancing underlying compocessing system reinforced the use associ nent technologies such knowledge based ation words and concepts implemented systems particular alternate approaches neural network Combining associative net symbolic manipulation provided connecwork with conventional system contributes tionist models Rumelhart have emerged semantic disambiguation the process Connectionist approaches enable the extracinterpretation The model employed within tion processing knowledge from examples kana kanji conversion system and the advan instead building knowledge bases manually tages over conventional ones are shown The model described here represents the unification the connectionist approach and conventional symbolic manipulation its most Introduction valuable feature the use word associations using neural network technology Currently most practical applications natWord and concept associations appear ural language processing NLP have been central human cognition Minsky realized via symbolic manipulation engines Therefore simulating word associations consuch grammar parsers However the curtributes semantic
Unless i am getting this part wrong but dont quote me on last bit :)
Its proberly not a vital thing but never really heard the term Compocessor used before.
    Intel Q6600
    eVGA 790i Ultra
    Corsair DDR3-1333 2 x 2Gb @ 1400mhz
    2 x eVGA GTX260 Super Clocked
    Seagate 80Gb, WD 640Gb and Ext 400Gb Storage
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks to you all, now i solved the problem when i downloaded the nForce Driver from the NVIDIA website as the chipset is manufactured by NVIDIA, i guess that the SM Bus Controller and Compocessor are things related to the Motherboard Chipset.
Thanks again for your efforts, Vista Forums is the best.
    AMD Phenom X4 9950
    Realtek HD Audio
    LG 19" WideScreen
    1152 X 864
    WD SATA 1TB
    Asus Vento
    Sky Tech Mini
    512Mbit/sec
nForce 15.24,
nForce Driver
  • Ethernet Driver (v67.89) WHQL
  • Network Management Tools (v67.91) "Sedona"
  • SATAIDE Driver (v10.3.0.42) WHQL
  • SATARAID Driver (v10.3.0.42) WHQL
  • RAIDTOOL Application (v10.3.0.42)
  • SMU Driver (v1.61) WHQL
  • SMBus Driver (v4.69) WHQL
  • Away Mode Driver (v6.0.6000.107) WHQL
  • Installer (v6.14)
should do the trick. Also do not install the two that are bolded; the first can be more trouble than it is worth, and still no idea what the second is supposed to do (can't find a straight answer anywhere ATM). Just make sure to uncheck them during the install.
P.S. here is the download page for an Asus board with the same chipset,
ASUSTeK Computer Inc.-Support-
Just get them from the Nvidia link as the download from Asus includes everything (motherboard and video) for both XP 32 and 64 bit as well as Vista 32 and 64 bit 9Basically 4 different driver packages in one and why it is over 500 MB).
P.S. Despite it not showing in the list of included drivers there is also a video driver included (not sure which version, but one from the 17x.xx series I believe) that you don't need to install. In fact you would probably be better off using the latest video driver (180.48) for your card,
http://www.nvidia.com/object/winvista_x64_180.48_whql.html
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Hi stormy,
This may help explain "Away Mode"
Away Mode in Windows Vista
As you say it's an Optional thing and the only reference to it, I have noticed, is an option in Power Options
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
nForce 15.24,
nForce Driver
  • Installer (v6.14)
This is the exact nForce driver i have downloaded and used and it solved the problem. :)
    AMD Phenom X4 9950
    Realtek HD Audio
    LG 19" WideScreen
    1152 X 864
    WD SATA 1TB
    Asus Vento
    Sky Tech Mini
    512Mbit/sec
