Driver Power State Failure....
Ninetyfourgoali
I don't know what this really means but I keep getting the blue screen of death that says Driver Power State Failure. I can't be on for more than an hour straight without my laptop crashing and that error comes up. I really have no idea how I would go about fixing this because it is really annoying when I am trying to do things and I don't want to possibly have my laptop die on me. I've only had it for 10 months...
94
could you go into c:|windows\minidump, zip the minidump file (*.dmp) and upload it to us.
If you need any help with any of it let us know
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
NFG
its a driver. 02sd.sys. Im looking up what it is a part of now.
here is the dump file anaylisys
ken
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Loading Dump File [C:\Users\K\Desktop\Mini092009-01.dmp]
Symbol search path is: SRV*d:\symbols*Symbol information
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible
Built by: 6001.18226.x86fre.vistasp1_gdr.090302-1506
Machine Name:
Kernel base = 0x81e1e000 PsLoadedModuleList = 0x81f35c70
Debug session time: Sun Sep 20 00:37:47.200 2009 (GMT-4)
System Uptime: 0 days 2:33:54.487
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 9F, {3, 87398030, 87398030, 8766d1d8}
*** WARNING: Unable to verify timestamp for o2sd.sys
*** ERROR: Module load completed but symbols could not be loaded for o2sd.sys
Probably caused by : o2sd.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 00000003, A device object has been blocking an Irp for too long a time
Arg2: 87398030, Physical Device Object of the stack
Arg3: 87398030, Functional Device Object of the stack
Arg4: 8766d1d8, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IRP_ADDRESS: 8766d1d8
DEVICE_OBJECT: 87398030
DRIVER_OBJECT: 86e1b8a8
IMAGE_NAME: o2sd.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 484e650c
MODULE_NAME: o2sd
FAULTING_MODULE: 8e949000 o2sd
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 81e51b5c to 81eeb0e3
STACK_TEXT:
81f13acc 81e51b5c 0000009f 00000003 87398030 nt!KeBugCheckEx+0x1e
81f13b28 81e516ac 81f13ba0 81f13c50 81f2c401 nt!PopCheckIrpWatchdog+0x1ad
81f13b68 81ed4c40 81f2c4e0 00000000 1a4ea4f4 nt!PopCheckForIdleness+0x343
81f13c88 81ed4800 81f13cd0 8ea45b02 81f13cd8 nt!KiTimerListExpire+0x367
81f13ce8 81ed43c3 00000000 00000000 0009084e nt!KiTimerExpiration+0x22a
81f13d50 81ed2edd 00000000 0000000e 00000000 nt!KiRetireDpcList+0xba
81f13d54 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x49
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: 0x9F_IMAGE_o2sd.sys
the only resources a can find on 02sd.sys say its either a driver or it is a virus.
Did you do a clean install? do you have a viurs app current and running?
have you installed anything other than the OS??
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Hey there
The majority of the references are that it is a valid driver for a sd card reader and that un-installing it and running with a generic driver will stop the BSOD's, and keep the card reader running.
I would still do a complete virus scan with a current Anti virus app to be sure
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Hey there
Ken
I've run virus scans literally whenever I get a chance. nothing comes up but I did have an SD card in the whole time the problem occured. I'll see if taking it out changes anything.
NFG
Ok it seems like the fujitsu sd card reader gets the blame on this one. after reading tons of info abt this, and the offending o2sd.sys file, the consensus if to remove the driver and let the generic card reader driver be installed. that will cure the bsod's I hope, but im not sure if the card reader will function 100% with the generic driver
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
NFG
Ok to remove the driver, go into device manager (type device manager in search) look for you card reader>right click>properties>driver>uninstall driver.
If you cant find the card reader device look for "unknown devices" they will have yellow triangles on it. One of them if you have them is probably the card reader.
If you want upload a screenshot of device manager to us by using the snipping tool that is built in (type snipping tool in seacrch)
If you need any help with any of this let me know
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
NFG
If you click on the "+" to the left of each category it will expand. find the one that says card reader. If it is connected via usb (external) it will be under usb. If not just open them one at a time till you find it
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
