driver is not compatible?
Superbunny
hello every one.
iv had a really out of the blue error, every time i boot i get
" At least one display adapter on the system has been disabled because its driver is not compatible with the driver for the VGA adapter. "
My system has been runing fine on that driver for months, i was lisening to my music, while playing a game then the screen turned off, and my pc crashed ( i know it crashed by the muic that was plying.
after a restart my pc was in 4 bit colour in a really low rez, i then desided to uninstall the driver, which did nouthing, so i pulled out the card, and tryed onborad, that worked fine with no driver, (never installed a driver for on borad).
The card that fails is a gforce 8500 GT pci-e
on borad i think is a 7600
othere system specs are
Cpu: althlon dual core 3.1 ghz
Ram: 6gb 800 mhz
mobo: Abit AN-M2HD
OS: vista ultimate 64bit
i have alos got to error repots form the event viewer, these are the 2 on when it crashed.
event ID 20001
Driver Management concluded the process to install driver FileRepository\monitor.inf_bf05f1f4\monitor.inf for Device Instance ID DISPLAY\GSM4A60\4&35491CE&1&UID256 with the following status: 0.
event ID 20003
Driver Management has concluded the process to add Service monitor for Device Instance ID DISPLAY\GSM4A60\4&35491CE&1&UID256 with the following status: 0.
Any help of this will be great, and a big thanks in advarnce
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
i have tryed to reseat i many times, even after a big cool down, and still the same, as for over heating, my pc is well vented also has
3 back fans
18 cm front fan
25 cm side can
over heating is not the case of couse theres a fan on it, if u couted all the fan arrond my pc, i have 8 fans.
it is weird, it just randomly struck
Can you try installing a new driver for that card? Nvidia are here:
www.nvidia.com/page/drivers.html
You could get a new card as that 8500 is old. A 9600GT would be enough or a GTS 250 for something stronger.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
tryed a diffrnt driver, and still
its safe to say its dead, which i did not want to happen, now i need to buy a new Power supply, 2 9800 gt's and a new mobo, an upgrade tht i wanted to do bit by bit, but now the 8500 is dead, ile have to get all at once, bu the plan was to get a mobo that can house two cpu's, buying all this in 1 lump will be too dear =(.
But why did it blow? i mean i did not OC it, it was well vented & cooled?
It is not necessary to get 2 new cpu's or run sli. If you play at 1920x1080/1200 then a single GTX 295 with a Core i7 920 is enough. That would justify the cost of the motherboard.
As to the card, sometimes the video processor fails. Maybe it was a dud factory card.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Try booting in safe mode, this will disable the driver on boot up.
If it will boot into safe mode then go to device manager and delete the graphics card form the list.
When you reboot the pc should install the driver for your card.
Try your card in a friends machine.
Have you tried booting into the bios with your graphics card installed on the machine? If this works then it is not a hardware error.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
from newegg with a 285 instead of 9800 & 295 and previously harvesting old dvd drive my whole rig monitor and all was just over $1600. Prices have gone down tho so u could upgrade or save some cash. Newegg gives 12 months no interest on a purchase that large with their preferred account.
    Home built
    phenom IIx4 810
    m4a79t deluxe
    8Gb DDR3 OCZ Platinum AMD Edition
    evga 295 co-op and 9800 gtx for PhysX
    Mk241H
    1920x1200
    Seagate Barracuda 7200 750Gb
    ABS Tagan BZ 800W
    Xclio A380PLUS-BK Fully Black
    Asus Royal Knight
    Logitech 5 button tilt wheel laser (don't remember model#)
    Razor Lycosa Mirror edition
    Wireless Road Runner
