LAXMetal23
Does anybody know if there is any way to get a driver to run in 32-bit compatibility mode? I have 64-bit and i use a usb to serial adapter cable by belkin and it only supports 32-bit and i use it to program the firehouse radios. I do not want to go out and spend 45 dollars on a new cable when this one is like 3 years old and works perfectly fine
