Solved Downloading Problem
catlady
I need to download iTunes 8.0. When ever I try to, this error message says "System Administrator Has Set Policies To Prevent This Installation." How can I change those policies? I'm using the Administrator account. I'm using Windows Vista Home Premium 32-bit. :cry:
catlady Welcome to the forums.
Are you saving or opening the download? If opening select save instead (save it to the desktop, makes it easier to find after), and then right click on it and select "Run as Administrator".
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
