Quartilius
Hello! Firstly Thank You for this great community for Vista troubleshooting
Problem...
A lot of the time when I download a file from the internet it won't run or install afterwards. There are a couple of different problems I've come across:
Windows Update: Some of the updates have successfully installed. Some fail to install every time.. I have 3 updates sat waiting to be installed but they fail when I try.
NForce Motherboard Driver: I downloaded the file from official website. Run the install program and half way through it errors: "The contents of this file cannot be unpacked. The executable you are attempting to run has been corrupted..."
I tried to download this file approx. 5 times. It makes sense that this error is because or a bad file, but I successfully installed the drivers by: Download the same file, from an XP machine, copy it over and install. I have this error alot, on different files not just the driver installer.
ITunes: Downloaded the Vista x64 version of this from Apple.com. When I run the installer (and as Administrator) I get prompted for the Admin Rights bit, click Allow and the application disappears and nothing else happens.
YouTube: As something I think's worth pointing out, if I stream a video on YouTube there's a good chance internet explorer will crash half way through the video.
My Spec...
OS: Vista Home Basic 64 bit
CPU: Intel C2D E8200 @ 2.66GHz
Mobo: GeForce 7100/NForce 630i Motherboard (by EVGA)
Network: Wired, Built into Motherboard
RAM: 4Gb DDR2 Cheap Stuff Corsair Value I think
GFX: GeForce 8500GT
Thanks for reading and I hope someone can help me!
(I'm pretty comfortable with computers, but Vista is brand new to me, so I apologize if I've missed out any necessary information but I should be able to get it for you if you can suggest something!)
Problem...
My Spec...
GFX: GeForce 8500GT
