Download Folder Problem
KHow
My username downloads folder would immediately cause explorer to stop working and restart, so I was unable to do anything with my downloaded files. I don't believe I downloaded any harmful things but something was up with the files so I wanted to delete them anyway. My only option was to completely delete the downloads folder, and now I don't know how to get one back.
I saw on a separate forum to type shell:downloads (enter) in the start search but this only brought up a window saying the search had no results.
I hope to get a new username downloads folder that gets the files when I download from firefox, obviously simply creating a folder won't work
any help is appreciated
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Your welcome glad it worked.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
It told me to do the shell command thing again but for some reason it worked :)
Thanks
We just told you in a better way....;)
Glad it worked!
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
