Does Vista output to SDTV ? 25i Hz ?
BeachNut
I need to output as secondary display to a SDTV (CRT) via S-Video for watching video (monitor is connected via DVI as primary display). I have latest ATI drivers. But CCC will only let me select 25i Hz for the TV out (monitor is ok at 60Hz) so video playback is a bit choppy. Other forums seem to indicate that this is a Vista issue - when I was using XP I could select 60 Hz for the TV. Just wondered if anyone knows of a fix for this ? (Vista x64+SP1). Thanks.
