You should upgrade or use an
alternative browser .
Do I need to do anything special after V 64 is installed?
Pain In The Butt
Power User
I have found all the 64 bit drivers that I need for all my components and all 64 bit software and have it ready when I install V64 on my new build. Is there anything special that I am going to need to do during install or after install that isn't in the norm when it comes to installation???
Genuine Home Built Grad A
Q6600
Abit IP35Pro
4GB Crucial Ballistix
VisionTek Radeon HD4850
HT Omega Claro
Sansung SyncMaster 2493HM
1900x1200
2 - internal seagate 500GB
1 - external 2TB NDAS server
P&C quad 750 watt
Antec P182
6016kbps
The only thing to be aware of is that on
a few systems Vista x64 will not install with 4 or more gig of ram
Operating System
Windows 11 Workstation
Ryzen 9 5950X
Creative
Drive
1500W ThermalTake Toughpower
ThermalTake Level 10 GT
Enermax Liqtech 240
Logitech Performance MX
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
HP CP1515n Color Laser
Microsoft LifeCam Cinema
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
z3r010,
If Vista will not install on a PC with more than 4 gig of ram is it possible to install with 3 gig of ram then add the ram after the install and it all should work? Thank You
Raj
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
Pain In The Butt
Power User
Well, I have 4gb of ram. Maybe I should install only 2gb just to make sure. Also, why is this happening?
Q6600
Abit IP35Pro
HT Omega Claro
1900x1200
P&C quad 750 watt
Antec P182
6016kbps
Pain In The Butt
Power User
Sorry, posted that after you posted.
Q6600
Abit IP35Pro
HT Omega Claro
1900x1200
P&C quad 750 watt
Antec P182
6016kbps
Most boards are fine, just load it up with all the ram in and if you run into any problems just knock it down to 2gig.
As for why it does it, its just a bug
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
Pain In The Butt
Power User
I thought you would know all z. I am surprised.
Oh, and by the way, I asked in another post where the donation part is. I would like to donate to the site.
Q6600
Abit IP35Pro
HT Omega Claro
1900x1200
P&C quad 750 watt
Antec P182
6016kbps
I must have knocked the donations link out of the template at some point
I have posted a link in the other thread until I fix the template.
Thank you
John
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
This thread has been most helpful. Thank you all!
ingeborgdot the donate button is at the very top of this window. I too am thinking of donationing as a holiday gift.
Raj
the patch is already on the sp1 beta if any of u guys are trying it...also you can lower the RAM bus speeds and the setup should work just fine...this way you dont have to open your computer up and remove and reinstall the ram
hope this helps
