DNS Server problem
Ok so I have a what I presume to be a networking problem.
IN the first 5 minutes of starting up my computer, I have access to the internet via internet browsers like Google
Chrome and Mozilla. However, after those 5 minutes, whenever I click a new page, it takes a long time to load and
eventually it stops loading.
Mozilla tells me this:
The connection was reset
The connection to the server was reset while the page was loading.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
while Google Chrome tells me this:
This webpage is not available.
The webpage at Google might be temporarily down or it may have moved permanently to a new web
address.
Here are some suggestions:
Reload this web page later.
More information on this error
I am fairly certain though that I am still connected to the internet because my torrents are
running/downloading/uploading/seeding and my Windows Live Messenger is still running. However I am unable to access
website pages.
The blue network icon at the bottom right hand corner of my computer tells me I am currently connected to my
wireless network and Access: Local and Internet.
When I click on diagnose problem, Windows Network Diagnostics tell me:
Cannot communicate with DNS server (218.186.1.58)
Network diagnostics pinged the remote host but did not receive a response.
Windows found a problem that cannot be repaired automatically...
My results of Command Prompt:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : User-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Wireless WiFi Link 4965AGN
Physical Address. . . . . . . . . : 00-1D-E0-5F-4E-85
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::7c68:931f:66a4:71ef%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, 31 December, 2010 12:57:06 AM
Lease Expires . . . . . . . . . . : Saturday, 1 January, 2011 1:14:12 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234888672
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0F-71-E5-10-00-16-D3-FB-7F-A9
DNS Servers . . . . . . . . . . . : 218.186.1.58
202.156.1.68
202.156.1.78
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-1E-37-9C-6C-C8
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Marvell Yukon 88E8039 PCI-E Fast Ethernet
Controller
Physical Address. . . . . . . . . : 00-16-D3-FB-7F-A9
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : isatap.{35A0F373-F46C-4B07-90F1-715B38DBD
787}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Local Area Connection* 15:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:3cb7:2a8e:c442:6dc5(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::3cb7:2a8e:c442:6dc5%12(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Windows\system32>NBTSTAT -n
Node IpAddress: [0.0.0.0] Scope Id: []
No names in cache
No names in cache
Node IpAddress: [192.168.1.102] Scope Id: []
NetBIOS Local Name Table
Name Type Status
USER-PC <00> UNIQUE Registered
WORKGROUP <00> GROUP Registered
WORKGROUP <1E> GROUP Registered
USER-PC <20> UNIQUE Registered
WORKGROUP <1D> UNIQUE Registered
..__MSBROWSE__.<01> GROUP Registered
C:\Windows\system32>Ping 206.190.60.37
Pinging 206.190.60.37 with 32 bytes of data:
Reply from 206.190.60.37: bytes=32 time=304ms TTL=44
Reply from 206.190.60.37: bytes=32 time=306ms TTL=44
Reply from 206.190.60.37: bytes=32 time=305ms TTL=44
Ping statistics for 206.190.60.37:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 304ms, Maximum = 306ms, Average = 304ms
C:\Windows\system32>ping yahoo.com
Pinging yahoo.com [209.191.122.70] with 32 bytes of data:
Reply from 209.191.122.70: bytes=32 time=239ms TTL=51
Reply from 209.191.122.70: bytes=32 time=237ms TTL=51
Reply from 209.191.122.70: bytes=32 time=235ms TTL=51
Ping statistics for 209.191.122.70:
Minimum = 235ms, Maximum = 239ms, Average = 237ms
C:\Windows\system32>ping hotmail.com
Pinging hotmail.com [64.4.20.184] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 64.4.20.184:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
So what indeed is/are the problem(s)? I have tried "ipconfig/dnsflush", "ipconfig/registerdns", "netsh winsock reset catalog" and "netsh int ip reset reset.log" but apparently they do not work. The only way around it is to switch off then on my modem and router only to have them fail on me again after 5 minutes.
Thanks in advance.
Have you tried using alternative DNS servers, such as OpenDNS (208.67.222.220 or 208.67.220.222) ?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Dwarf: Where or how do I input those alternate DNS servers? In TCP/IPv4 or TCP/IPv6? In my router settings or where? I have tried several places using trial and error but they do not work.
Lottiemansion: What do you mean by should I be routing through Singapore? I am using my own wireless home network.
The DNS you are referring to (address 218.186.1.58) is located here: -
    40 Meg
Hello,
My thoughts are around malware, the DNS is not exactly local to you & therefore could be a
re-direct. If this is your choice of a preferred DNS then fine. Otherwise I would recommend a scan: -
Malwarebytes
    40 Meg
You're using a Singaporean proxy, proxy.xxx.xxx.xxx.xxx.maxonline.com.sg, so it would be perfectly normal for your DNS server to be Singapore-based. Unless explicitly set in the router settings, your DNS server will be allocated by your ISP (or proxy server, should you use one).
    Gigabyte IF233
I highly doubt that the problem is malware-based because indeed that DNS is my preferred choice. And like Dwarf said it is perfectly normal.
Ok if I use either Google's DNS or OpenDNS servers, Windows Network Diagnostics tell me: Cannot communicate with DNS server (The DNS address I used)
However, after some meddling with the router settings, something is different now. If I set my TCP/IPv4 back to "Obtain DNS server address Automatically", Windows Network Diagnostics tell me: Cannot communicate with Primary DNS server.
Is this indication a good thing or what?
Do you now have a mixed set-up? ie Windows manually set & router on auto.
Set both to auto & try again. Once that is working reset your manual setting to what you like to have in the router & leave the PC on auto.
    40 Meg
Ok thanks guys for all the suggestions but the problem seems to be fixed. After some more meddling with the router settings, during which it went haywire, I decided to reset everything (using the disc the router came with) and it fixed the problem, for now I guess. I will post again if I run into future problems though. In any case, thanks for all the wonderful suggestions.
