Display Settings Keeps Opening
ronrontiu
Whenever I use a program that changes the resolution, Display Settings opens automatically. This wasn't an issue before and recently, it just started happening. Anyway to stop this?
    Athlon 250 @ 3Ghz
    ECS 6100pm
    2GB DDR2
    9800gt Inno3d Green
    1366 x 768
Hello Ron,
Do you remember if you have installed or changed any settings right before this started?
You could try a system restore using a restore point dated before this started to see if it may be able to fix it for you.
