Display Problem / Graphics Problem
fields999
I have a problem, for some reason when im playing games such as cod4 or gta4 or something. Il be playing fine for quite a long time, certainly a few hours but then randomly the screen will just stop, and the whole computer will freeze.
I noticed that on the frozen screen small parts of it had small purple lines going round them.
Well the only way to get out of this is to do a hard boot and start up my pc again.
Im wondering why this happens as i have all up to date drivers and my pc easily meets the requirements to play the games im playing.
Any help would be greatly appreciated, thanks.
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
Check the GPU temperature, and if there is enough room for the fan.
It could even be a problem if the card isn't inserted properly or something.
Cheers..
    Compaq Presario C700
    Intel Core 2 Duo 1.67 GHz
    Intel GM965
    2.5 GB (2 GB Transcend + 512MB Hyundai)
    Intel Intergrated 965 Express Graphics
    Conexant High Definition
    Compaq
    160 GB Compaq
    Alps Pointing Device Touchpad
    Compaq
    2 Mbps Download, 512 Kbps Upload
    Integrated Web-Camera (P.S. Have another custom-built PC with Win7 x64)
Heat could be a problem, more so if you say it only happens after a long period of time playing the game.
Also, corruption of a driver could easily make trouble for you... I usually try a new fresh install when this happens just for good measure.
One more thing I would check is your Monitor Driver, if it is recognizing your monitor, no problem but, if all you see is "Generic or Std PnP or Non-Pnp monitor" you should seek a newer driver for it.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Download HWMonitor and post a screenshot here so we can see all the values.
Cheers,
Madhan
    Intel GM965
    Compaq
    160 GB Compaq
    Compaq
At last ........ everybody blames heat for every issue with a gpu , finally somebody with symptoms that actually point to a heat issue ;) Or your cards ram is overclocked too high or its faulty
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Ok i ran some tests, i did it with the hwmonitor one and with pc wizard.
The temperatures seemed fine to me, and i my pc had been on all day, under the same conditions its under when it sometimes compeltely freezes like i said about.
Aswell none of my cpu or graphics cards have been overclocked i should mention.
Thanks
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
yes mate but thats your core temp (you also need to monitor it ingame as it'll get alot hotter) , im talking about about your onboard memory possibly being either faulty or getting too hot , there a a few common related symptoms to games freezing/ locking up , most commonly it a ram issue (system memory not gpu memory) but if you also get graphical abnormalities as your getting it points to your cards onboard memory that MAY be at fault.
How to help you troubleshoot the issue is a problem , you can only do so much over forums i can spend hours asking you to do this that and the other and it'll turn out to me something silly , computers are like that , you always tend to overthink the problem ;) so first job make sure your card is correctly seated and is plugged into any relevant supply correctly.
I would clock back the ram a little and see what happens , if you get no joy the only other altenative is to strip the card down clean it with an alcahol based cleaner the reseat the ram heatsink/s with a decent heatsink paste such as arctic silver (but i realise this can sem a bit daunting if you have never done it before)
start with the obvious , make sure its pluggen in properly give it a good blow out and make sure the fans clear then clock back the ram just a wee bit
Its not still under warrenty by any chance is it?
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
I think the first thing il do is clean it outand check its all connected propperly, ive had it for about a year or so and ive switched it over from my old pc to my new one.
I dont think it would be a problem with my system memory, i mean there all new sticks of ram 3x 2GB and 1x 1GB all DDR2.
thanks
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
as i said ,
simple freezing - system memory
freezing with graphical abnormalties - GPU memory .. read the post!! ;) ;)
Oh and i cant remember how many "new" sticks of bad memory ive had in the past there have been so many :P
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Hi fields999,
Looking at your system specs, I'd say look at your memory configuration. With four dimm slots, I wonder what config you're running to have 7 (seven) gig of memory???
I'm guessing 3 two gig modules + one 1 gig module? That could be a problem in itself. I'm also guessing these aren't matched.
Try running with just 4gig (2x2gig) and see what happens?
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Im not sure that id want to downgrade back to 4gigs of ram, but when i get home il clean out all my gpu as i think it may be pretty thick with dust etc.
Il see what its like after that and il see how hot it gets while ive been playing a game for quite a while.
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
oh hang on , your using one of those hybrid motherboards , im not sure how they work do they automatically clock up the gpu when a game is detected or do you do it manually?
This could be a fault with the "geforce boost technology" whatever the hell that is
im ducking out of this one , the problem most likely exists in there somewhere ive never had any experience with it , all looks a bit hit and miss to me :P
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Hi fields999,
I think you're missing my point, but ok.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
what sygnus is trying to say and what ive been saying is 99% of the time issues like this are related to your ram not your gpu (or your gpu onboard ram)
you have a very odd configuration of memory it could be causing problems so what he is suggesting is remove some of your ram , leave in 2 x 2gig sticks (matched pair) and see if it helps :D
you will notice no loss of performance ingame 4 gig is fine , its worth a shot at least it'll only take you 2 seconds to do ;)
we cant help unless you give our ideas a go :P
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
He is not asking you to downgrade, merely suggesting you try with 4 GBs of Ram for Testing Purposes, matched if at all possible. Newer memory dimms come matched (dual channel) and they work best this way. Sorry can not really explained it, google it and you'll find an answer.
If after 30 minutes of heavy gaming, you get no Freezes, Locks or BSODs, then you know your problem may lie with your RAM and not with Video Driver or GPU issues.
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
