Solved Display cable
Ayson
I use a LCD tv for my monitor. Currently im using a VGA cable to connect it. My 3D card has a DVI out and my TV has an HDMI in. So will it be better to use a DVI-HDMI cable. The VGA cable im using is a cheap one and seems to be having a shielding issue.
    NA
    AMD Athlon X2 64 4800+
    ASUS M2N-MX SE
    2x2GB DDR2 667MHz Transcend
    BIG GeForce 8600GT 512MB
    Realtek HD 5.1 onboard
    Sony Bravia V Series - KLV-26V300A
    1360 x 768
    WD Caviar Blue WD5000AAKS 500GB SATA
    Enterage Power3 400W
    Enterage Generic
    Stock CPU fan, Stock GPU fan, 4x Chassis fans
    UMAX USB
    UMAX PS2
    2MBPS
    Philips SP050 60W RMS 5.1 2x1TB in Vantec NexStar MX
Hello Ayson,
You would be much better off using a DVI to HDMI cable. It will give you a lot better picture quality.
thanks for ur advice
    NA
    ASUS M2N-MX SE
    1360 x 768
    Enterage Generic
    UMAX USB
    UMAX PS2
    2MBPS
You're welcome Ayson.
