DiscCleanup will not run
Skugge
Hello!
I'm having trouble with the DiscCleanup in Windows Vista.
When I try to open cleanmgr.exe for C: it opens for a second but closes fast when it comes to "Setup Log Files"
Cleanmgr.exe worked fine for C: before a security update from windows update was installed.
Is there a way to fix this?
Regards
Skugge
Windows Eventlog:
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2009-01-11T13:42:41.000Z
EventRecordID 1242
Channel Application
Computer
Security
- EventData
cleanmgr.exe
6.0.6000.16386
4549b0a8
cleanmgr.exe
6.0.6000.16386
4549b0a8
c0000005
000034ef
14bc
01c973f278fc0f4d
Have you tried to run it just from Explorer/Computer and right clicking on your drive ? ?
How long are you waiting as the first time it is ran it takes awhile.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
Hi!
Yes, that is normally the way I run the Cleanup tool. I have tried all possible way to run cleanmgr.exe. If I understood the second line correctly, I dont have to wait for it start, it just closes right away. It's almost impossible to see what is causing the application to quit so fast, but if I push the DiscCleanup button many times i see it closes when it comes to Setup Log Files
Skugge
Hello Skugge, and welcome to Vista Forums.
You might try a System Restore using a restore point you believe is dated before this problem to see if it can fix it.
Thank you! And thanx for your answers.
I have just done a clean installation of Vista 32 bit sp1 today, the Cleanup tool worked just fine for C:, after I did a windows update the problem occured.
Is there a registry fix or some log files that has to be deleted, as I can see cleanmgr doesn't like the "Setup Log Files"
Skugge
I don't know exactly witch one it is, but I remember it was some months ago MS released a high security update for internet explorer when it happend.
Skugge
Download CCleaner, its just as good if not better than the MS disk cleaner, and its free.
    Asus x83vb-x1
    Dual Core T2750
    Asus
    4Gigs 433MHz
    Nvidia Gforce 9300M GS
    14.1 in.
    250gig 500gig external
    Cable 54MB/s
Skugge
Skugge,
Since you do not have a restore point to use and do not know which update it may have been, then you might see if running a sfc /scannow command can find and fix and bad or missing system files that may be causing this as well.
If this does not help, then you can do a repair (upgrade) install.
@ Brink
I'm sorry to say, that didn't fix the problem.
I would hoped a registry change or deletion of a log file could have solve this.
Skugge
I do not know what else to suggest other than the repair or clean install since the other options did not pan out for you. :(
It's ok, but thanx for trying to solve this problem. :)
I have done a clean vista sp1 install and after the 22 security updates from Windows Update, I know one of them is causeing this problem. I know that because right after one of the monthly updates from MS I tried to Clean up and it didn't work. Now as the fresh Windows Updates shows the same date, it's not easy to point out witch one them it is. I hoped MS made an fix for this as time went by, but none came, and now it seems like it's not coming.
Skugge
