Direct3D Acceleration Disabled
foxbat91
I'm running Vista Home Premium 64 bit and installed an Nvidia GeForce 9800 GT graphics card. I installed the current drivers but can't get [FONT=&quot]Call of Duty World At War or FarCry 2 [/FONT][FONT=&quot] [/FONT] to run. I ran dxdiag, under the display tab I see the following:
DirectDraw Acceleration: Enabled
Direct3D Acceleration: Disabled
AGP Texture Acceleration: Enabled
When I run the 64 bit DxDiag,iIt tells me that all 3 are enabled.
[FONT=&quot]I also ran the System Requirements Lab Analysis on the NVIDIA site and it reported that I don`t have Video Card 3D Acceleration or Video HW Transform + Lighting.
I had the card checked and it is working fine.
Does anybody have some suggestions?
[/FONT]
I don't recall if this problem was with these 2 games but, when you were trying to install it, did it ask you to install DX9? if so, did you allowed it to do so? Since none of those two games are DX10 native, you may have a corrupt DX9 installed, try to uninstall or reinstall a fresh copy of both DX9 & DX10 just for good measure.
I could be totally wrong here but I doubt you will botch anything but re installing your DX9 & 10.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
have you tried reinstalling your GPU driver..??, install it in ''safe mode'' see if that makes a difference.....;)
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Click the first link in my sig and under step 2 download and install the DirectX, C++ etc and then reboot your pc.
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
