Direct x 10 (MAJOR PROBLEM)
Stef10
Hi
I recently bought a new rig and Windows vista home basic and i have a major problem.
My hardware specs:Intel i7 (920 clocked @ 3.8) with a 850w corsair is my PSU, Graphics card: gtx 295 EVGA and 6gb of ram, My motherboard: Gigabyte UD5 i7
My Software: Windows Vista Home Basic x64
I am having issues with Direct x 10, everytime i try to run a game.exe it runs in Direct x 9.0c, now ive downloaded the latest forceware drivers for my card, tried to run it in administrator mode and everytime i right click a game.exe vista does not show run in direct x 9 or 10.exe's.
I have also tried to clean my graphics card drivers in safe mode, downloading EVGA drivers afterwards, this still does not work.
In dxdiag it also says im running in Direct x 10.
I have a question, i installed a 32 bit ver of windows on the system by mistake then formatted the HDD and installed vista 64x would this have anything to do with the issue im having? (most of my files are moved to program files x86).
Oh and one more crucial thing, ive tried to update Direct X 10 on their website, the update just installs 9.0c because im on sp1, i have also tried to update to sp2, the same problems occurred, did a fresh format back onto SP1.
Please help me, this is really anoying, ive just put together a nice rig, and its REALLY anoying when it only runs in DX9.
Thanks
Stefan
Hello Stef10,
What game is it you are trying to play in DX10 ?.
What error are you getting when trying to update to SP2 ?.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thats the thing, i apologize i didn't explain the SP2 update correctly.
I can update to sp2 no problems, but directx 10 still will not run.
List of games:
Stalker clear sky
Crysis
Cryostasis
Far Cry 2
When you go in to the in game menu in Farcry2, and Crysis, under video options does it give you the option to run in DX9 & DX10 ?.
Also, if you right click the Crysis shortcut does it give the DX9/DX10 option ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
How are you checking to see what version of DX it's running in ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
hey stef10 hi and welcome
Just a heads up because you are new. This is the same topics' second post in gaming, and in general. double posting makes it confusing for everyone. Try not to, OK
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
That's a good question, as I didn't know you could do that. At any rate I just click on the .exe and choose either DX9 or 10.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
As you have seen FC2 has the option in-game. Crysis on the other hand will default to 64 bit and DX10 when install on Vista (or Windows 7) x64 and a DX10 video card is detected. to get the game to run in DX9 mode you need to right click on the game's shortcut, and you will find it and a few more options.
Can't help with the other two as I don't have the games.
In game open the console (the ~ key usually) and type "r_displayinfo 1" (without the quotes). To get rid of the info, tpye the same in again only instead of 1 it is 0.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
When I got my new computer, Vista Home x32, I tried to play Everquest. Didn't work. I had to install DirectX 9c in order to play Everquest. It has worked fine since.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
