Hello guys,
Lately I bought a new nice laptop with a strong cpu and lots of ram. The reason was, that a wanted to use it for both gaming, programming, designing and recording music.
This other day, I finaly had enough saved up for buying the M-Box 2 with Pro Tools software. At this point, I realised, for my big dissapointment and confusement, that it wasn't supported for my Vista system?
I learned, that Digidesign doesn't support Vista Home Basic, and overall doens't support 64 bit systems!? Ok, maybe this is Digidesign's problem, but then again - if I had known this before I bought my laptop, I would surely have bought a mac instead, so at that time it gets your problem.
My question is therefore: Why is M-Box 2 and Pro Tools not supported for x64 Vista systems, and why only a couple of x32 systems? This is simply not good enough, and I really must underline my dissapointment in this case.
When will it be compatible to my version of Vista, or just any x64 Vista systems?
I hope I can get a good answer from you guys
Regards,
The dissapointed danish musician Max Boderskov
Regards,
