Ok, I'll explain this the best as I can but Im still totally mistified as to what happened :sa:
I went home for lunch yesterday and used my desktop as usual, its a dell XPS 630I and Ive had it maybe 4 months total. I just checked my email and logged back off to the user screen. While I was gone it kicked into hibernation mode like it always does when noones using it....
When I got home like 4 hours later I moved the mouse to bring it out of sleeping and nothing happened the screen stayed blank. So I waited and waited and it never kicked back on so I manually restarted it with the power button and it loaded to the dell screen which took alot longer than normal to load, right after that it popped up "Error Loading OS". I tried restarting and hitting the F8 button... no luck.... I hit F12 and tried running the diagnostics... nothing came up...
I put the dell cd in that has vista on it and hit the repair button near the bottom of the install screen and ran the different tests and nothing came up wrong. However I tried the memory test and it started I needed to reboot in order to use it... however when I did that it kicked back to the "Error Loading OS" screen...
So thats where I am right now and I have no clue what to do, I am going to just do a clean install but theres stuff Id really like to get off this drive before I wipe it clean.... Any help you can give would be greatly appreciated.. Im totally outa ideas and calling dells customer support you need a translator to get anything accomplished
Please help!
Please help!
- Dell XPS 630I
