You should upgrade or use an
alternative browser .
desk top keeps going black
every time i reboot i lose my desk top it goes to a plain black back ground i can put a theme on ok but when i restart my computer it goes to a black screen.
Hi Lindon-p,
You might try booting to last known good configuration (F8 while restarting) or do a system restore to a date that you know it worked on.
Did you install anything (programs or updates) or make any changes before this happened?
Hope this helps some,
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
No programes just changed the theme with vista home prem there no restore points saved unless you save your self last known does not work tried that.
thanks anyway
Lindon..
Ok,
Try setting the theme back to the one you had before.
Operating System
Operating System
microsoft have done an update to sort this out it been caused by 1 of there updates and abobe reader 8
thanks for your help Lindon
OK,
Glad to hear it's working for you now.
Operating System
Operating System
