DEP Problems
hermit
Vista Home Premium, 32bit: I've read the tutorials here on how to enable DEP (Data Execution Prevention), but there are a few problems. First of all, there are two locations where different DEPs applications can be changed or turned off/on. The first one resides in the 'Advanced System Settings' > 'Performance' > Data Execution Prevention' tab. The two choices here are: Use DEP for Windows programs & Use DEP for all programs. Mine was set by default to the former, but when changed to the latter, web pages would no longer load ("server not found" or "unable to load..." So I had to reset to the default level. Q: What causes the problem? Is there a solution?
Isn't my comp. better protected with DEP enabled for all programs?
DEP's second residence is in IE > 'Internet Options' > 'Advanced' tab under 'Security.' The options here are to check or not box saying 'Enable memory protection to help mitigate online attacks.' The tutorial here tells me to right click on the IE7 exe. file, but I can't find it. Right clicking on IE in menu brings up 'Run as Admin' prompt then redirects/connects to 'hp.desktop.aol.com.' But by the time I get to the 'Enable memory protection...' box, it's grayed out & won't let me check it. Research says this is disabled by default. This is a new desktop. Shouldn't this DEP be enabled as well? Please help the dummy.
Some of my applications don't support DEP. You can either disable DEP for those applications. Some motherboards have hardware DEP feature. Does your board?
    16GB DDR667
    SAS RAID
Hello hermit.
Welcome to the forums!
This is from OPTION TWO of the tutorial... Look at it again!
1. Open the Start Menu.
2. Click on All Programs and right click on Internet Explorer, then click Run as administrator.
NOTE: If you cannot get IE7 to open using step 2, then click on All Programs and Accessories. Next, right click on Internet Explorer (No Add-ons) and click Run as administrator instead.
WARNING: If you do not use Run as administrator, the Enable memory protection to help mitigate online attacks option will be grayed out in steps 5 and 6 below.
DEP is best left enabled; re-read the entire tutorial and see if you missed something.
I hope this helps you.
PS, you're not a dummy we all have to learn!
later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Mike: Yes, my system supports DEP.
Ted: I have done it both ways in your suggestion (as the tutorial specifies), but I get the same result either way: when right clicking IE > Run as Admin > I'm redirected / connected to hp-desktop.aol.com. When I am at the 'Enable memory protection ....' box,
it is still grayed out.Can you speak to the issue of pages not loading or server not found when DEP in enabled for ALL programs & services?
My thanks to you both for your help.
Jeff
Hello again hermit!
Lets work on this one issue at a time.
Are You going here... Start Orb > All Programs > Accessories > System Tools > Internet Explorer (No Add-ons) <-- Right Click; then L Click on "Run As Administrator" L. Click "Allow" for the "User Account Control" pop up. Then click on Tools (@ tool bar) > Internet Options
This way the DEP box will not be greyed out.
View attachment 4469 View attachment 4470
Give this a try and post back.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
BF Kid: You get the Gold Medal Award of the week!! You solved my problem. Thank you kindly. Can you speak to the issue of pages not loading / server not found when DEP enabled 'for all programs & services except those I select' in the system area?
Hello again hermit.
I'm glad you got that one sorted.
I'm not sure about the other issue; consider adding more info on exactly
what you're referring to.
If you can't get some answers in this thread start a new one with all the
relevant information concerning the problems you're having.
Keep looking up!
Later :shock: Ted
EDIT: You may find this useful... http://www.vistax64.com/tutorials/65790-dep-turn-off-programs.html?ltr=D
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
