Default mail problem
dcronje
When I click any e-mail link in Vista, I get the error message:"...default mail client has not been installed properly."
Default program is Windows Mail. How can I fix this problem?
dcronje,
Download the reg file and merge it from the NOTE under step 4. It seems like you lost your MAIL TO protocol. This will add it back for you.
It would not hurt to make sure that Internet Explorer has all of it's default associations set to it as well.
OK, I got it right. Under the help files I had to open "Set Program Access and Computer defaults", then "Custom" and then I had to check IE and Windows mail.
