Custom Splash boot screen help
my school has asked me to make a splash screen that will boot up when we turn on the computer, is there any simple tutorials on how to do this for windows XP, not using software cause we have to make one custom image to clone on to all the PC's
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
Hello,
I am more than happy to help with this, however, I don't really understand which splash screen you wish to change. Is this the logon screen, and remember that several stages need pictures in 16 colours, not 16 bit. If it is the boot screen (and I doubt it is), see here for all methods.Change XP Boot Screen
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
i need one that is for the bios screen or the loading screen for XP and it needs to be programless
i gota do it by hand cause i need to make a image of the OS with it on it for like 100 computers
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
Hello,
I see your point about 100 computers, however, that does not necessarily mean programless. For example, for the computers that are the same, the Resource Hacker program will modify ntoskrnl.exe for one computer. You can then roll this new ntoskrnl.exe file into the Windows installer/whatever method you use for deployment(such as network install) before deployment.
For BIOS splash screen, see the very bottom of that link I gave you, its all in there!
Good luck, although remember that this is hacking and may just ruin everything. Also, be particularly careful with the BIOS one, a bad BIOS flash can be quite annoying (although modern computers with Boot Block Sectors should not be too difficult to fix)
Because this functionlity is not built into Windows, you will need to use a program, but programs before deployment are fine. Be careful not to deploy an incompatible ntoskrnl.exe!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
If you are talking about this:
Link: http://www.jakeludington.com/windows_xp/20060219_change_xp_boot_screen.html (from niemiro)
There is a program called... Stardock.com LoginStudio.
Link: Stardock.com - Your Edge In Software
    Customized PC
    Intel Core i7 920 (2.66GHz)
    ASUS P6X58D Premium Intel X58 ATX SATA 6GB/s USB 3.0
    DDR3-2000 CL9 6GB (3x2GB)
    HIS ATI Radeon HD5970 GDDR5 2GB
    N/A
    HDD #1: 160GB 2.5" SSD HDD #2: 2TB Seagate Barracuda XT 64MB Cache SATA 6GB/s
    Corsair TX850 850W
    Corsair Obsidian Series 800D Full Tower
    N/A
    Razer Mamba Wireless Laser Mouse
    Logitech G19 Gaming Keyboard (with LCD Display)
    N/A
    Logitech Z5500 THX 5.1 Speaker System, Razer Destructor, LG BH08LS20 DVDRW + Blu-ray Writer
