C0MM4ND312
I got a problem with the Audiodg.exe process, problem is that sometimes it uses from 5% cpu and jumps to 50% and more and when playing this makes everything choppy and even cause mouse lagg..
As fast as i tab down the game the process drops to 5-10 and if I tab in again it jumps and holds on for several sekunds/minutes and then everything works fine and some minutes later it starts again.
This Hapends when playing all sort of games but mostly hapends in Counter Strike Source, and Windows Media Player, when watching films or listening to music but when doing that it gets worse and making the sound to lagg or slowdown etc.
Any idea? got all the latest drivers exept for bios becouse Asus bios are unstable, and i cannot switch audio drivers becouse i got 4gb of ram and only the latest creative drivers work with 4gb...
Hope you understand everything
Spec:
OS: Windows Vista x64 Build Version 6.0.6001 (SP1 ENG)
Motherboard: Asus Crosshair nForce 590sli
CPU: AMD 5200+ FX-62 Dual Core Black Edition
RAM: 4x1gb Corsair Dominator 1066mhz (running only 932)
Sound: Creative Elite Pro
GFX: nVidia Gainward 8800GTX
PSU: CoolerMaster Real Power 1000watt
HDD: 2x Western Digital Raptors X (2x150gb)
IDE: 1x DVD Liteon x8 burner and 1x CDRW Lite On Burner x52
USB 2x USB Devices Mouse and Keyboard
Lan1 1 Ethernet cable
Lan2 Disabled
Nothing gets overheated etc...
Everything got latest drivers etc...
Hope thats all, Best Regards C0MM4NDER
Spec:
Lan2 Disabled
