Connectivity Problem
Ajju
I am not able to connect my pc with internet when I was trying to shift it on different default gateway. Currently I have two default gateways; one is 192.168.1.1 and second is 192.168.0.1. I have ten PCs, Out of 10 and 8 PCs are on 192.168.1.1. And two PC are on 192.168.0.1, these two PC are automatically getting there IP address with default gateway 192.168.0.1. So I want to put these two PCs on 192.168.1.1, so manually I changed the default gateway to 192.168.1.1 but after this , these two PC’s was no longer active their connectivity to the internet vanished. So is there any solution to put these two PCs on 192.168.1.1 default gateway???
Beside that when I was trying to view network connection , the next 9 PCs are not available , means some available and some not , same situation for every PC , If I individually check view network connection some PCs are available but some not.
Second thing I want to add every PC on same workgroup, so can I able to accessible each document of share drive from each PCs
So anyone knows solution for both problems…????
Thanks very much
Thanks very much
I see you are using XP and you've posted this in a forum that supports Vista.
You didn't say what any of the PC's are using as operating systems. I believe in XP there is a limit to how many machines can connect at the same time depending on whether it's Home or Pro version of XP.
Perhaps if you can post back with details of just what the machines use someone will be able to point you in the right direction. ;)
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
