Connecting to an XP PC printer to a Vista..
RotaryP7
Before making this thread I searched and tried everything since last night.. I finally gave up. As you can see I'm trying to connect my Vista x64 laptop to a shared printer on my network which is running on an XP machine. I can see the PC and printer but when I hit select, it fails to connect to it because it keeps telling me wrong drivers installed or something and it tells me to search for them. What I did after wards was connect the printer locally to my laptop to install the drivers needed for Vista. No luck when trying to connect to it again wireless. Same error message.
Any help? I'm new to Vista..
Printer: Brother MFC-7420 (it's already on shared)
    Asus laptop
    Intel Core2 Duo T5800 2.00 GHz
    Nvidia GeForce 9300m GS
    14.1"
    250GB SATA (5400 rpm)
    Cable - Wireless - 8/16 megs
You have to be in the same subnet. File and Print sharing enabled on both computers. You go into the printer folder and share the printer.
\\computer\printer_share is the printer.
    16GB DDR667
    SAS RAID
Well, I have the firewall with Norton and it's set on shared. I think my Windows firewall is disabled so it wouldn't matter.
I don't get what your saying though? The printer is shared from the host PC.
    Asus laptop
    14.1"
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Asus laptop
    14.1"
On XP computer, you configure the printer and set up printer sharing in the printer setup.
You need file and print services enabled.
Your router needs to allow file and print services
On Vista, you add a printer, choose network printer, go to your workgroup, find the XP computer and under it should be your printer.
both computers must be in the same subnet and workgroup, you also need them to have security rights to browse for the files and printers.
    16GB DDR667
    SAS RAID
Ok, I'm getting somewhat closer. I found the shared printer and I even added the printer so it looks like it works.. Thing is, I can't print. Test page isn't working.
    Asus laptop
    14.1"
I seriously cannot get it to work.. It's connected to the printer but it's not printing.
    Asus laptop
    14.1"
Do you have rights to print on that computer from your Vista account? I usually put the same username and password on all workgroup computers.
    16GB DDR667
    SAS RAID
I should be able to. It just keeps saying error printing when I print from my laptop. I've already connected my other desktop PC on XP to that same printer and no problems..
    Asus laptop
    14.1"
What is the error? Can you print a test page?
    16GB DDR667
    SAS RAID
Have you tried reading my tutorial... It might help.
Click HERE for the tutorial :)
    Acer Extensa 5620-6396
    Intel Core 2 Duo 5750
    4GB DDR2
    ATI Radeon HD 2400 XT
    Laptop 15.4 LCD
    1280*768
    Logitech G11 Gaming Keyboars
Yea, I can't print the test page, says error.
That was one of the first things I did.. I tried it before even making this thread. It installed the printer and everything and I tried printing and nothing..
    Asus laptop
    14.1"
Alright I did it. It finally worked after having the drivers needed and whatnot. Don't really know what the problem was all I know is now it works.. And I want to thank you guys who helped me. Vista isn't easy and I'm glad I found this forum.
Thanks again to all, issue solved. :)
    Asus laptop
    14.1"
