Connecting PC to TV
gillder
Just caught Windows.ca advert on TV which showed a young child watching his computer cartoon animations on TV. Begs the question - how do we connect PC to TV? I'm told all I need is an S-video cable, which I bought for $100, but still no connection. Can anyone help me with this please? Thanks.
Derek
what kind of video card do you have?
also does you tv have a s-video input?
    Q6600 Core 2 Quad
    Asus P5NE SLI
    OCZ Platinum XTC 8GB Dual Channel PC6400 Memory - DDR2-800MHz, Enhanced
    SAPPHIRE HD 4870 X2 2G GDDR5 PCI-E
    HP w2207h
    OCZ GameXStream 700-Watt Power Supply
    Ultra Aluminus ATX Full-Tower Case - Black
    Merc Gaming Keyboard
Thank you for picking up my query. I don't know about what sort of video card I have although the word Nvidia is present. However I do have s-video ports in both PC and TV. The $100 cable when connected reveals absolutely nothing. Hence my question.
one thing you might try i do not know if it will work or not
plug the svideo into the computer and the tv diconnect your monitor
turn your tv on (s-video) then boot the computer see if anything shows up on the screen
keep in mind i do not have a nvidia card i have ati cards and that is what i did to get one of my computers to work on a tv
    Q6600 Core 2 Quad
    Asus P5NE SLI
    HP w2207h
To turn on the TV You will need to open personalization option. Do so by right clicking the desktop and choose personalize. Then click on the display option and you will see your tv grayed out. Click on it then find the option to extend your desktop to that monitor. After you turn it on you can set the resolution for the TV.
if your TV is on the left side of your PC then you can grab the number 2 monitor and drag it to the left side of monitor 1 and hit apply. this way your mouse will pass from one to the other like the two monitors are one.
If you need any more help or if I was not clear enough please let me know.
Later,
DemonSeed
P.S.
If I helped you out please give me some rep by clicking the little scales in the upper right corner. Thank You
    Custom Built Rigg "My Baby"
    AMD Athlon 64 X2 4200+
    ASUS M2N-E SLI
    6GB DDR2 900 Kingston
    BFG Nvidia 9600 GT-OC + BFG Nvidia 9600 GT-OC
    SoundBlaster XFI
    Acer 19" WideScreen + Ascer 22" WideScreen + Acer 19" WideScreen + HDTV
    1680x1050 + 1400x900 + 1920x1080
    Seagate 500GB Sata Seagate 500GB Sata Seagate 500GB Sata Seagate 500GB Sata Seagate 320 Sata (Primary) Western Digital 500GB IDE Western Digital 500GB IDE Western Digital 300GB IDE Maxter 720 Sata (USB)
    BFG 800 Watt SLI Power Supply
    Game Master
    Thermotake
    Logitech (Bluetooth)
    Turbo Cable
    ATI 650HD TV Tuner X2
I have a DELL Inspiron 1525 laptop, trying to connect to a Samsung LCD TV. Using a vga cable I am seeing only the background of my laptop after making adjustments to connect the PC to TV.
At one point I was prompted by a window asking what mirror image I prefer. Apparently I selected the wrong one. After numerous attempts, I have been unable to see anything more than my desktop background on the tv. All windows I can see on my laptop are not transferring to the tv.
How do I change settings - where do I go, what do I do?
I hooked up the comp to a Toshiba LCD.
I had to go into configuration and change the "input" to PC. When I did so it recognized the PC and auto adjusted the resolution and refresh. Now I have a 37" PC monitor.
