You should upgrade or use an
alternative browser .
Solved Connecting My Vista System To the Wireless Router
Is there a document or something that I can read which will tell me step-by-step how to configure Winvista to connect wirelessly to my router? I plan on using Firefox as my browser.
Operating System
Windows Vista SP2 32-bit Home Premium
HP a6400f
3 GB
Integrated
Samsung 27-inch
500 GB Internal
Not connected
Hi skeezix:
You might find some helpful information in my 26-Jul-2024 post # 2 in Ace!'s
No Internet Access .
Operating System
32-bit Vista SP2 Home Premium
HP Pavilion dv6835ca
Quanta 30D2 (U2E1)
3 GB RAM
NVIDIA GeForce 8400M GS
Operating System
64-bit Win 10 Pro v22H2
Dell Inspiron 15 5584
Intel i5-8265U @1.60/1.80 GHz
Dell Inc. 07R8NW
8 GB DDR4 SDRAM
Intel UHD Graphics 620
Imacri,
Following your suggestion, I started my Vista OS computer and got to Windows Network Diagnostics. And from there I found that I had no wireless adapter installed.
So I guess that's that!
Thank you for helping me out.
Operating System
HP a6400f
3 GB
Integrated
Samsung 27-inch
500 GB Internal
Not connected
I started my Vista OS computer and got to Windows Network Diagnostics. And from there I found that I had no wireless adapter installed....
Hi skeezix:
Be sure to double-check in
Device Manager under
Network Adapters to confirm you don't have a wireless adapter. The image below shows my Vista machine has a separate Intel 4965AGN Wireless (WiFi) adapter and a Realtek RTL8101E Ethernet NIC (Network Interface Card).
Some computers have a combination Wireless (WiFi) / Ethernet NIC in a single device.
Operating System
Quanta 30D2 (U2E1)
3 GB RAM
Operating System
Dell Inc. 07R8NW
8 GB DDR4 SDRAM
