connect burner
kandieoneluv
I have three computers. Two have Vista already on them. I yet to update the third so I have XP on it. Media 11 says connect burner, how do I go about this.
Hello kandieoneluv,
Is this on the XP or Vista machine ?.
By burner, it means a CD/DVD drive, confirm that your drive is working, try playing a CD/DVD.
Also you can go to Device Manager, un-install the drivers for you CD/DVD drive and reboot, it will reload the drivers on boot up, and confirm that your drive is being recognised by Vista.
Right click on the icon of your CD/DVD drive from within My computer > properties > recording tab, check to see if it's set to record from your device.
Try this and post your results, good luck.
If this does not work there are other solutions to the problem, it's just this is the easiest to start with.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
