Conexant HD audio problems
aneirin
Hello,
Ever since I tried to install Service Pack 1 (which seemed to require driver updates before it could be installed), the sound on my laptop has refused to work. The volume control doesn't work and insists that there is no audio output device, whereas the Device Manager says that the Conexant HD Audio device is there, but that the drivers are not installed... but when I try to reinstall the drivers, it tells me that the installation has 'failed', but doesn't tell me why. Does anyone have any idea what I can do? Thanks!
Well, according to Device Manager, the driver that's installed is version 4.40.0.50 (15 February 2008), so I'm guessing that'll be the latest one. I reverted the installation of SP1 earlier, by the way, so that's not installed now (I thought it might be causing the problem).
Well if you decide to try again, I would visit the your motherboard manufacturers site and ensure you have the latest drivers from them and not just generic drivers. I'm not sure if you've already done that, but its worth a shot.
A lot of people seem to miss the idea that, when installing SP1, if any of your devices break, the first thing to do is to re-install the latest drivers for that device - SP1 doesn't' play nicely with all devices and their drivers, and a simple reinstall will usually (but not always) fix it.
Glad you got it fixed, and thanks for the patience in trying something that did not seem to make a difference before *again* - perseverance was the key to your success, and I hope others will read this thread and try the latest drivers before starting to pull their hair out.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
