Computer running hot?
Smurfyy
Danny :)
Heyy everyone!
this isnt a problem, just a question...
In the UK its getting hotter and so is my computer.
I just looked at my temp display and it shows 35 - 37 degrees C without my fans on, when i turn the fans on it goes down to 32 - 33.5 degrees C.
Is this hot/life threatening for the computer?
Thanks,
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Heyy everyone!
Thanks,
Daniel =)
In answer to your question, no it's not life threatening it's actually quite good.
It will only have the potential to do damage when it reaches 70 or 80+ and even then there's no guarantee anything will break if it's only for a short time; it also depends on your hardware configuration.
Most CPUs and GPUs have a built in cut off temperature (usually 100ºC) at which they switch off to prevent damage anyway.
Oli
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS) External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
Ahaa, okay.
I was just worried because its never gone over 30 degrees C.
Thanks!
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Ahaa, okay.
Thanks!
Daniel =)
If you think it's running abnormally hot I recommend two things:
Check your thermostat or ambient room temperature.
Check to make sure no unnecessary programs are running in the background heating up your CPU.
I'm looking forward to the 25ºC on Friday. :D
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
Ahaa, okay.
Thanks!
Daniel =)
Oli
Okay, thanks, ill try that.
And yes, so am i! gunna go out down the beach after school methinks, get some mates out with me, awww yea,,,, sunny nights, hot air, fresh grass, blue sky! SUMMER 2010!
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Heyy everyone!
Thanks,
Daniel =)
Oli
Roflmao If it reaches over 100 the cpu will fry
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Lol, yeah.
I was talking about case temps...
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Heyy everyone!
Thanks,
Daniel =)
Oli
Not necessarily. It could continue to function if there was no humidity in the air and no plastic anywhere near it, although the likely hood of that ever happening is so low that to be safe they put in the 100ºC cut off (interestingly mines 105ºC though :s).
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
Oli
Oli
I remember finding this video on youtube, and it was intel V amd when heatsinks are removed, amd just fryed up, intel just slowed right down until the heatsink was replaced.
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
