I have two questions. First: Is there a patch for running 16 Bit Software on a windows vista 64 OS. The error message I am getting states: "The version of this files is not compatible wiith the version of windows you're running." My second question: How do you check your system information to see whether you need an x86 (32-bit) or X64 (64-bit) version of the program?
jtwest777
jtwest777
- HP Pavilion / dv5-1004nr
- AMD Turion X2 Ultra Dual-Core
- 4096MB DDR2 SDRAM (2Dimm)
- ATI Radeon HD 3200
- 15.4" Diagonal WXGA HD
- 250GB (5400RPM)
